Are you referring to a Golf or Passat Alltrack?
As I thought the Passat ran a 235 tyre...
Hi all,
I need to replace tires on our new to us 2013 Passat Alltrack.
Currently it as ContiPremium Contact 2 225/50 r17
What tires are others running?
Any advice appreciated.
Depends what your doing with it what if any off-road driving do you do?
If you do a lot you may want to go a higher sidewall and more aggressive offroad tread
If 99% on road have a look around there are lots of tyres in that range depends on what you want to pay vs grip/wear
If you like sporty driving a slightly lower ie 45 sidewall and sticky tyres (expensive) i changed to 235/35/19 in my golf alltrack (with a rim change of course) it rides and handles vry nice on hankook ventisv2 tyres not super expensive about 270ish each tyre i think and give a good ride with good grip wear is unknown atm as only have 1k on them
2017 Golf Alltrack 135tdi All options
19 inch Brescia Wheels Golf R brakes front and rear
Calipers painted Candy apple gold
New rear sway bar and linkages
