Interesting - good to know someone has the same issue...I think!
What is DPF?
2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
What is DPF?
Diesel particulate filter - for tdi engine.
A diesel particulate filter (DPF) is a device designed to remove diesel particulate matter or soot from the exhaust gas of a diesel engine.
Sent from my SM-G960F using Tapatalk
Ok thanks
How do you know when the car is doing a dpf?
Increasing rpm...then i switch to sport mode and drive with rpm around 2000.
So drove home tonight - freeway for approx 30 mins temp gauge hovered at the 70-80 mark. Oscillating between the two.
Parked at the shops, 5 mins later jumped back in started up and the gauge sat on 90 as it should!
Not really a problem but annoying me all the same!!
Interestingly it is doing that oscillating when I go up and down hills which makes me think it’s the airlock issue but I can’t seem to get the burping and farting to happen!
Hi
Just to explain my experience. Usually, temperature gauge was oscillating between 80-90C. During dpf regeneration temperature was dropping to 50-60C ???
Together with all of that dpf regeneration become every day routine...
Replaced dsg thermostat - totally another story. Temperature gauge stays on 90C. No dropping or oscillating temperature at all. Dsg regeneration is not every day anymore.
Dsg thermostat cost 100$ and installation by dealer 150$...
I hope this helps...
