My TDI took about 5-10mins to get to normal temp of 90Deg. After I had the timing belt and water pump done I had a similar occurance Temp actually dropped while climbing a hill.
Solution get it hot, when you park in the garage take the cover off the coolant reservoir listen for air coming up. Leave till next day and see if it happens. There is also a thermostat on top of the transmission that can cause that.
I bought one thinking I needed it and didnt so its in the cupboard Cost $50
