Hi got the airbag fault this morning. Have read it can be the connector on the front driver or passenger seat. Attached is a shot of the passenger side Is it worth disconnecting and then re connecting? Heard they can corrode over time. Does the battery need to be disconnected when you pull the connector? Apparently this was the subject of a recall in US and Europe? Any one else had this fault and what was the fix? Thanks![]()
B6 Passat Wagon No KESSY
Thanks gavin anyone in melbourne got vcds
Yep, airbag and ABS faults won't self clear.
Side impact sensors under the rear seat are common on the Passat.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Took it to bayford in fairfield clise to home 165 down the toilet for diagnostic and clear code now it is back they reckon it could be the wiring on the passenger seat which is a known issue is this a hard one to fix yourself? Can you ditch the connectors and wire directly ?
Yes, you can bypass the connectors, but VW strongly recommends the red Duraseal (eBay them. Cheap as) connectors to crimp join the wires and seal them.
'01 Beetle 2.0
Thanks umai you da man so asy to do and then ckear the code with vcds?
Thinking of having a go at fixing this myself. Any tips / tricks to removed the seat? I have heated seats as well.
Thanks
Steering wheel controls and horn have stopped working so suspect clockspring now
Drop me a PM if you need a hand sorting it out mate. Located in Sunshine West.
