getting in done at Volkwerke today needs a new clock spring as suspected. Lucky they had a part here.
If your airbag fault is just wiring, you got off lightly. I needed a new airbag control module for a mere $840 + labour.
2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
B6 Passat Wagon No KESSY
For future reference if anyone is reading this in the future, airbag fault clear in VCDS needs to be done from the airbag module itself, not from the check codes section. Mine triggered once during some spirited driving when traction control came in particularly hard, worked out not to be a real fault, thankfully.
