I just checked with VCDS and I have 3AA 614 109 AF Abs pump. I have a 2012 B7 manual. Is it capable of supporting Adaptive cruise control?
vag guru in russia flashed my ecu (2.0 tdi)
no error front assist now
need to change brakes line in dump file
Yes any 3AA abs can be modified to support ACC.
Your ecu aso just be able to however...
Sent from my SM-G960F using Tapatalk
Can this particular one support it without being modified? And what about the ECU?
Thanks for replying. Your build is class.
Depends on the ECU.
If it's a Bosch med/EDC can probably be unlocked in the software by a tuner.
If it's PCR probably not.
Hi Kamold, your ACC retrofit guide has inspired me to do the same to my MY11 Passat B7 wagon. I'm so keen and can't wait as I have pretty much all the parts except for the radar sensor itself. Been struggling a bit to find a not-too-expensive B7 3AA radar but have found a couple of affordable B6 3C0 ones. Would the 3C0 be compatible with the B7? If not, can the 3C0 radar be flashed to work with the 3AA firmware?
Might be able to assist you there...
Check your messages
Wow thanks so much for this information!
Unfortunately, I contacted drsedoy about it back in January last year, but he has not responded since. I've tried again now. Now im looking for someone who can edit my dump with this information.
@kamold I tried to deactivate the error code myself, but I can't do it with the DTC Remover. I hope you still have time to have a look on it
