Page 9 of 9 FirstFirst ... 789
Results 81 to 82 of 82
Thread: Adaptive Cruise retrofit
  1. #81
    Nov 2021
    Hi guys, having some spare time this past weekend, thought I'd kick-start the retrofit on my B7. I began with just plugging in the electrical side of the used ABS 3AA614109D which I got from Germany. Obviously had some warning lights come up at ignition on. Tried setting the coding similar to what I had on my original ABS. Wouldn't let me change anything at all, said something along the lines of invalid coding. Do you guys know if we need SA to be able to change ABS coding at all? Thanks!
    Note: Can post autoscan later if required.
  2. #82
    The coding string needs to be valid to be accepted.
    Not enough info to go on.
    Post autoscan with your original ABS connected.
