Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 82
Thread: Adaptive Cruise retrofit
  1. #61
    Jun 2019
    Hi Kamold,
    The full VCDS scan is too large to paste here. Can I send it to you in an email?
  2. #62
    Jun 2019
    Just a massive thank you to Kamold for taking the time to sort out my issues with ACC and Front Assist yesterday. You are an absolute legend!!!Adaptive Cruise retrofit-acc-jpg
  3. #63
    Hi Kamold,
    I try to install the ACC-System on my Passat B7 wagon too. But the ABS-hydraulic block won´t accept the coding. I bought, depending on the Information that I found in your thread, the ABS hydro block number with letters AR. Is there an additional step needed before the new code is accepted from the ABS ?
  4. #64
    Quote Originally Posted by DerRasendeRoland View Post
    Hi Kamold,
    Need some more information - ideally a full VCDS autoscan.
  5. #65
    Jan 2021
    Germany
    Hello kamlod, I have also converted a lot of my Passat B6 to B7 and now have the same problem that you described here.
    https://www.motor-talk.de/forum/acc-nachruestproblem-t6074218.html
    02186 - Motor-ADR interface
    How did you get it solved
    Samstag,16,Januar,2021,14:32:56:00009
    Fahrzeug-Ident.-Nr.: WVWZZZ3CZ9E104633 Kilometerstand: 277050km
    Adresse 01: Motorelektronik (CBB) Labeldatei: DRV\03L-906-022-CBA.clb
    Teilenummer SW: 03L 906 022 QG HW: 03L 907 309
    Bauteil: R4 2,0L EDC F000AG 6212
    Revision: 13H01--- Seriennummer: VWZCZ000000000
    Codierung: 0050078
    Betriebsnr.: WSC 18689 807 682182
    VCID: 7AFB47EF35DF50565C-802E
    2 Fehlercodes gefunden:
    053283 - Steuerger‰t f¸r Abstandsdistanzregelung
    U1023 - 000 - Bitte Fehlerspeicher auslesen - Sporadisch
    Umgebungsbedingungen:
    Fehlerstatus: 00100000
    Fehlerpriorit‰t: 6
    Fehlerh‰ufigkeit: 1
    Verlernz‰hler: 255
    Kilometerstand: 276991 km
    Zeitangabe: 0
    Datum: 2015.06.08
    Zeit: 08:18:11
    Drehzahl: 782 /min
    Geschwindigkeit: 0.0 km/h
    (keine Einheit): 0.00
    (keine Einheit): 3.0
    Bin‰rwert: 00000111
    050227 - Abstandsdistanzregelung
    U0433 - 000 - unplausibles Signal - Sporadisch
    Fehlerpriorit‰t: 2
    Fehlerh‰ufigkeit: 1
    Verlernz‰hler: 255
    Kilometerstand: 277032 km
    Zeitangabe: 0
    Datum: 2015.06.08
    Zeit: 17:18:19
    Drehzahl: 2300 /min
    Geschwindigkeit: 118.0 km/h
    (keine Einheit): -3.40
    (keine Einheit): -2.20
    (keine Einheit): 1.0
    Bin‰rwert: 00100001
    Readiness: 0 0 0 0 0
    Adresse 02: Getriebe Labeldatei: DRV\02E-927-770.clb
    Teilenummer SW: 02E 300 043 T HW: 02E 927 770 AJ
    Bauteil: GSG DSG AG6 431 1999
    Revision: 04743012 Seriennummer: 00000801180745
    Codierung: 0000024
    Betriebsnr.: WSC 00066 123 12345
    VCID: 25414493ECE10FAE41-8070
    Kein(e) Fehlercode(s) gefunden.
    Adresse 03: Bremsenelektronik Labeldatei:. DRV\3AA-698-109.lbl
    Teilenummer SW: 3AA 698 109 N HW: 3AA 614 109 AQ
    Bauteil: J104 C2 450M VE9F 0042
    Revision: --H07--- Seriennummer: 00000006780851
    Codierung: 0116156
    Betriebsnr.: WSC 12345 123 12345
    VCID: 4487F917079BD6A676-8010
    Adresse 13: Distanzregelung Labeldatei: DRV\3AA-907-567.clb
    Teilenummer SW: 3AA 907 567 A HW: 3C0 907 567 J
    Bauteil: AC201 RDW A 031 0170
    Revision: 00031000 Seriennummer: 00000000035098
    Codierung: 0010000
    Betriebsnr.: WSC 00399 211 80519
    VCID: 387F9DE74B538246EA-806C
    1 Fehler gefunden:
    02186 - Motor-ADR Interface
    008 - unplausibles Signal - Sporadisch
    Fehlerstatus: 00101000
    Fehlerpriorit‰t: 6
    Fehlerh‰ufigkeit: 2
    Verlernz‰hler: 199
    Zeitangabe: 0
    Datum: 2015.06.08
    Zeit: 08:17:56
    Anzahl: 34
    Adresse 16: Lenkradelektronik Labeldatei: DRV\3C0-953-549-SW25.lbl
    Teilenummer SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
    Bauteil: J0527 0030
    Revision: 00032000 Seriennummer: 3C9953507CR
    Codierung: 0201822
    Betriebsnr.: WSC 05314 000 00000
    VCID: 74E769D717BB262606-8020
    Subsystem 1 - Teilenummer: 5K0 959 542 A Labeldatei: DRV\3C8-959-537.CLB
    Bauteil: E221__MFL-TAS H07 0013
    Codierung: 00000130
    Betriebsnr.: WSC 00000
    Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\3C8-920-xxx-17.clb-SRI1
    Teilenummer SW: 3AA 920 880 H HW: 3AA 920 880 H
    Bauteil: KOMBI H05 0505
    Seriennummer: 00000000000000
    Codierung: 061F01
    Betriebsnr.: WSC 05314 115 12345
    ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A04716
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
    VCID: 387F9DE783538246EA-806C
    Adresse 19: Diagnoseinterface (J533) Labeldatei:. DRV\7N0-907-530-V2.clb
    Teilenummer SW: 7N0 907 530 BC HW: 7N0 907 530 AN
    Bauteil: J533 Gateway H56 1663
    Revision: H56 Seriennummer: 060913F1002159
    Codierung: 462006
    VCID: 72EB6FCFADAF281614-8026
    Adresse 25: Wegfahrsperre Labeldatei: DRV\3C0-959-433-25.clb
    Teilenummer SW: 3AA 959 799 A HW: 3AA 959 799 A
    Bauteil: IMMO 070 0402
    Revision: 00070000 Seriennummer: VWZCZ000000000
    Betriebsnr.: WSC 32821 003 1048576
    VCID: 4683E31F31A7E4B668-8012
    Subsystem 1 - Teilenummer: 3C0 905 861 G
    Bauteil: ELV 027 0380
    3C0905861G ELV 027 0380
    Adresse 53: Feststellbremse Labeldatei: DRV\3AA-907-801.clb
    Teilenummer SW: 3AA 907 801 H HW: 3AA 907 801 H
    Bauteil: J540 EPB4 VW-86594 0010
    Revision: H19 Seriennummer: 00000000161378
    Codierung: 0022157
    Betriebsnr.: WSC 44954 123 92704
    VCID: 366393DF41477436F8-8062
    Adresse A5: Front-/Vorfeldkamera (R242) Labeldatei:| DRV\3Q0-980-65X-A5.clb
    Teilenummer SW: 3Q0 980 654 H HW: 3Q0 980 654 A
    Bauteil: MQB_B_MFK H04 0272
    Seriennummer: 16121511K11511
    Codierung: 000408020000040100260045C086A00080000E120000
    Betriebsnr.: WSC 00046 000 00000
    ASAM Datensatz: EV_MFKBoschMQBB 001001
    ROD: EV_MFKBoschMQBB_VW46.rod
    VCID: 3C7781F7B76BAE660E-8068
    3 Fehlercodes gefunden:
    1135153 - Grundeinstellung
    B1828 F0 [008] - Laufzeit¸berschreitung
    Sporadisch - best‰tigt - gepr¸ft seit letzter Lˆschung
    Fehlerstatus: 00000001
    Fehlerpriorit‰t: 4
    Fehlerh‰ufigkeit: 1
    Verlernz‰hler: 193
    Kilometerstand: 276657 km
    Datum: 2021.01.04
    Zeit: 23:27:30
    Steuerger‰tetemperatur: 29 ∞C
    Auflentemperatur: 1.5 ∞C
    Fahrzeuggeschwindigkeit: 0.00 km/h
    Systemlaufzeit: 1186.5 s
    Spannung Klemme 15: 12.9 V
    mid: 00 1B
    Status der Kamera: Systemfehler
    Engine_Running_Info: 0
    Software_Info_4: 2
    Software_Info_3: 7
    Software_Info_2: 2
    Software_Info_1: 0
    Ende----------------------------(Dauer: 03:32)-----------------------------
  6. #66
    Modify the ecu software to not log the fault.
    If you can get a read of your ECU with something like KESS, MPPS, Galetto etc I can get it modified to remove the ECU side fault which stops the issue from causing a braking disengagement situation.
  7. #67
    Jan 2021
    Germany
    thank you for the offer. I have a colleague who I could send an identical ecu to, which he could then read out. Does he have to flash it with KESS again or can I do it with VCP?
    why do my post above you just disappear?
  8. #68
    If it's read with KESS will need to be written again with KESS most likely. I don't know if VCP can necessarily write a KESS MED9.1 flash read.
    As a general rule it's best to use the same tool as was used to read, to do the write. Most ECU tools will correct the ECU checksum at the write step. So if you're checksum is written incorrectly the ECU could be bricked.
    The posts looked like duplicates (x3)
  9. #69
    Jan 2021
    Germany
    So it will be KESS
    I think removing the error code will definitely prevent the ACC from being switched off. However, in this situation the ACC still does not behave as smoothly as the old combination. Since you switched directly to 3AA ACC, the comparison is missing here.
    drsedoy from the drive2 forum has had a similar experience and apparently made further adjustments to the ECU. The ACC brakes earlier and the "emergency situation" is practically avoided.
    I have a friend who can lend me KESS for some time, so that I first program the DTC code and then deal with other ACC fields in the ECU.
    Maybe drsedoy will answer my request and I will get some information.
  10. #70
    The way I understand it, (this is purely speculation), the problem arises when regular ACC braking tries to transition to front assist braking. There is an unexpected command received by (or sent by) the drivetrain controller (the ECU).
    This causes the incompatibility fault and disengagement of ACC braking, which is obviously dangerous.
    As it is now with the modified ECU software, in this instance the fault code is logged in the ECU, however it does not cause a disengagement, so braking continues. The fault is only noticed if doing a scan.
    The fault code itself could be masked in the ECU so that it doesn't log at all.
    There may well be a way to modify the MED9.1 so that it operates in the same way as the MED17 in B7 (or EDC for diesel) but the complete answer may be an ECU upgrade.
    (Watch this space )
