Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 82
Thread: Adaptive Cruise retrofit
  1. #51
    Quote Originally Posted by Юрий View Post
    Hi, how to change eeprom abs, I have abs 3aa614109ag changing in eprom ag to as, diagnostics does not see the block number at all
    hello
    no answer?
    i found information about 3C0 and nothing about 3AA EEPROM
  2. #52
    If you cannot see the ABS unit on diagnostics there is something wrong.
    Check the eeprom is ok and correctly installed.
  3. #53
    hello kamold
    What the content from the range EEPROM need to replace?
    in ABS 3C0 need replace 0x2BA-0x2BF... to activate ACC
    what i must to do with 3AA dump?
    thanks for the reply
  4. #54
    Check your PMs
  5. #55
    Jun 2019
    Hi Kamold,
    I recently purchased a MY10 R36 wagon and found that all the Adaptive cruise control functions weren't turn on when I checked with my VCDS cable. After following your coding instructions I can get the ACC to respond to the stalks but I get ACC fault on the MFD and doesn't work. My wagon looks like it has all the goodies from factory. Can you please help as I've been at a loss to get it running. Thank you in advance.
  6. #56
    What is the actual fault?
    Note that my retrofit was with B7 (3AA) parts and yours being factory fitted is 3C0.
    The coding is not the same as the 3C0 version does not support follow to stop for example.
    Please post the actual fault code ideally in a full autoscan from VCDS.
  7. #57
    May 2015
    I can't give any technical input, but as I have factory fitted ACC I might be able to help from an operational perspective. Can you turn on the Front Assist on the MFD? Can you activate the cruise control from the stalks? Occasionally I have had an ACC fault on the MFD but when I restart the car again it has gone and the ACC works normally.
    Biscay Blue MY10.5 Passat R36 Wagon
    Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
    Atlantic Blue MY19.5 Golf GTI
    Options: Luxury Package and Sound & Style Package.
  8. #58
    Jun 2019
    I had to activate the Front assist functions in VCDS by playing around with it and now it appears in the MFD with a check box. When I tick it the message comes back as Assistant fault on the screen. I will upload a full autoscan later on this evening. I find it strange that all the ACC and front assist functions were all turned off even though the hardware exists on the car. Thanks again.
  9. #59
    They might have been disabled because there is a fault...in order to not display a fault on the car at time of sale...
  10. #60
    May 2015
    That's an interesting thought. For me it was the exact opposite. The (non VW) dealer who sold me my R36 didn't know it had ACC, I only discovered that it was fitted after I bought it! It is a fantastic feature to have.
