Post the full autoscan here to be sure.
But it's likely to be 0001439.
HELP PLEASE
Hi there i have a 2008 vw r36 wagon it has 129k on clock its been parked up in shed for little while battery went dead so replaced i now have 3 dash lights on abs/stability control and rear reverse and fog bulb. Have plugged vcds into it and its missing coding for abs module how can we get a code for it.??
Saturday,12,March,2022,14:01:07:38195
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210226 DS325.0
Ross-Tech: Home
VIN: WVWZZZ3CZ9E019200 License Plate: LCM393
Mileage: 130000km-80778mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 2E 36 37 42 44 46 52
53 55 56 57 62 6C 72 77
VIN: WVWZZZ3CZ9E019200 Mileage: 130000km-80778miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (BWS) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 AM HW: 03H 906 032 AB
Component: R3.6-FSI-EU4 G 2150
Revision: 5GH04--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 05311 000 00000
VCID: 6D87C2DB2198AD53545-8038
1 Fault Found:
004506 - Fuel Pressure Sensor (G247)
P119A - 001 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 129961 km
Time Indication: 0
Date: 2021.12.29
Time: 03:28:35
Freeze Frame:
RPM: 663 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 61.0∞C
Temperature: 32.0∞C
Absolute Pres.: 1010.0 mbar
Voltage: 13.462 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 012 E HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1903
Revision: 04843012 Serial number: 00000805230567
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 127DB1275866D2AB297-8046
No fault code found.
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
Component: J104 C4 440 V2 0011
Revision: --025--- Serial number: 00000785758954
Coding: 0001439
VCID: 2B030CC3DF0C63630A1-807E
2 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 130000 km
Time Indication: 0
Date: 2022.01.05
Time: 02:56:39
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 13.00 V
Bin. Bits: 00011111
Count: 227
Hex Value: 0x0000
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Mileage: 130000 km
Time Indication: 0
Date: 2022.01.05
Time: 02:56:39
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 13.00 V
Bin. Bits: 00011111
Count: 149
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 DA HW: 3C0 907 044 DA
Component: ClimatronicPQ46 132 0811
Revision: 00132023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6393A4E3F75CEB23F21-8036
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000008449259
Coding: E68E8F0700041A00470A00000F000000000B59435C00012000 0000000000
Shop #: WSC 05124 000 00000
VCID: 71BFDEAB3DA049B370D-8024
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 200508 022 0601
Coding: 00046997
Shop #: WSC 05124
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 160608 054 0402
Coding: 00733421
Shop #: WSC 05124
2 Faults Found:
01502 - Bulb for Rear Fog; Left (L46)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Mileage: 129961 km
Time Indication: 0
Date: 2021.12.29
Time: 03:44:00
Freeze Frame:
ON
Voltage: 12.70 V
ON
ON
OFF
OFF
OFF
01519 - Bulb for Back-Up Lights; Right (M17)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Mileage: 129961 km
Time Indication: 0
Date: 2021.12.29
Time: 03:44:00
Freeze Frame:
ON
Voltage: 12.70 V
ON
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 3C8 919 475 HW: 3C8 919 475
Component: PARKHILFE 8K H07 0007
Revision: -------- Serial number: 97530815900374
Coding: 300103
Shop #: WSC 05314 000 00000
VCID: 71BFDEAB31A049B370D-8024
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0069
Revision: 00000000 Serial number: 28050800920003
Coding: 010180
VCID: 6695BDF7086E9E0B15F-8032
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__016 VW10 HI 1815
Revision: 19013000 Serial number: 0039BPAPBRNF
Coding: 0012598
VCID: 7AADF98760D60AEBC17-802E
Subsystem 1 - Serial number: 6333FTS623821338
Subsystem 2 - Serial number: 6343FTS653181418
Subsystem 3 - Serial number: 6353ETS6QD11TVNP
Subsystem 4 - Serial number: 6363ETS69GLKTVNP
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 AC HW: 3C0 953 549 AC
Component: J0527 0020
Revision: 00026000 Serial number: 3C9953507AR
Coding: 0001212
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 H HW: 3C0 920 871 H
Component: KOMBIINSTRUMENT VD1 2416
Revision: V0002000 Serial number: 00000000000000
Coding: 0007505
Shop #: WSC 04963 002 1048576
VCID: 290FF6CBD5F07173F8D-807C
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 H HW: 3C0 907 951
Component: J533__Gateway
' 0142
Revision:
' Serial number: 2600P085270168
Coding: FDABFF06C04612F100
Shop #: WSC 73020 981 58226
VCID: 2615FDF7C4EE5E0BD5F-8072
2 Faults Found:
01305 - Databus for Infotainment
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 17
Mileage: 129961 km
Time Indication: 0
Date: 2021.12.29
Time: 03:26:23
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 17
Mileage: 129961 km
Time Indication: 0
Date: 2021.12.29
Time: 03:27:07
Address 22: AWD Labels: None
Part No SW: 0BS 907 554 HW: 0BS 907 554
Component: Haldex 4Motion 4011
Coding: 0000005
VCID: 03538463171C4B23921-8056
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 S HW: 3C0 959 433 S
Component: IMMO 041 0383
Revision: 00041000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 3A2D39872056CAEB817-806E
Subsystem 1 - Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 2E: Media Player 3
Cannot be reached
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1101
Revision: 00005000 Serial number: 00000000000000
VCID: 2F3B18D3EB141F43269-807A
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1518
Revision: 71009005 Serial number: 00000539188529
Coding: 0005047
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 209 2501
Revision: 00H15000
Shop #: WSC 17380 143 30549
VCID: 2C010FDFDA02645B03B-8078
Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
Component: KSG PQ46 ELV 041 0472
Coding: 0091020051030E76300494157008DFCE707801
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Subsystem 3 - Part No: 3C0 951 171 C
Component: Innenraumueberw.004 0611
1 Fault Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 18
Mileage: 129961 km
Time Indication: 0
Date: 2021.12.29
Time: 03:44:11
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1518
Revision: 71009005 Serial number: 00000064688525
Coding: 0005046
VCID: 72BDD1A738A672AB897-8026
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 008 Serial number: 00000000040116
Coding: 0000057
Shop #: WSC 05311 000 08193
VCID: 2809F3CFCEFA487BE73-807C
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0133
Revision: 00H04000 Serial number:
Coding: 2346241
VCID: 343117BF02323C9B5BB-8060
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000035
Address 56: Radio
Cannot be reached
Address 57: TV Tuner
Cannot be reached
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000000439021
Coding: 0000144
VCID: 70B9DBAF36AA40BB7F3-8024
Address 6C: Back-up Cam.
Cannot be reached
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000000446210
Coding: 0000144
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 03:11, VBatt start/end: 13.3V/13.2V)-----------
hi here is the scan the two majors i need to resolve are the abs and reverse light and fog light
That seems a bit unusual.
The coding is correct.
Try setting coding to 0000000, save, then cycle ign and set coding back to 0001439.
For your rear lights they have an electrical fault. Start with fuses, globes.
I advised contacting a licensed Volkswagen dealership or a skilled auto mechanic when trying to get a code for the ABS module. They will have access to the equipment and materials needed to find the proper coding for your ABS module.
When you get a chance have a read of this post:
Replacing rear brake pads causes EPB fault (vwwatercooled.com.au)
perhaps you might find something useful there.
2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 368K ... and still going
