Results 11 to 20 of 21
Thread: 9WZ Bluetooth install
    Mar 2014
    Melbourne, Vic
    The 9wz needs pairing for Bluetooth and selecting of the phone for media via the cluster, after that play a song and the Bluetooth button should show up under the media menu of the rns
    Jun 2015
    Willy, Victoria
    Quote Originally Posted by rjt86 View Post
    Thanks mate. I got it working a couple days ago. There are still a couple things that are bugging me and I'm not sure if there is a way around them (at least not that I have found).
    1. Every time I get a notification for a text or email or whatever the audio in the car gets silenced for about 5 secs. That happens whether I'm listening to the radio or a cd. Really annoying. I can't find any settings on the head unit or the cluster to stop this. Is there anything in VCDS?
    2. When playing music through BT the sound only comes out of the 2 front speakers that are used for phone calls. None of the other speakers work. This means all of the mid and low range is lost. When you change the volume the volume bar comes up green and says telephone. The tone button on the head unit doesn't do anything so you can't set the balance etc. It seems that music is playing through the telephone connection rather than a true BT media link. Also really annoying...
    Any help much appreciated!
    Mar 2014
    Melbourne, Vic
    Number 1's defiantly a RNS setting in a menu, there's a check box to play Bluetooth audio or something automatically ( off the top of my head) will check for you soon as i need to head to the shops.
    Number 2- didn't have that issue with mine, what harness did you use to install the kit? Did it have the 2 quad lock connectors or did it involve some wiring and splicing?
    What's the part number of the Bluetooth unit?
    Jun 2015
    Willy, Victoria
    I've tried that both off and on. No difference.
    The harness with the dual quad connectors. No splicing required.
    5N0 035 730 D
    Mar 2014
    Melbourne, Vic
    Hmm the one i was thinking of is the "Bluetooth audio auto play" function under setup> media
    Pretty sure that's the same model Bluetooth unit I have also.
    Did you do any coding after it was installed?
    Jun 2015
    Willy, Victoria
    Hmm the one i was thinking of is the "Bluetooth audio auto play" function under setup>media
    Yup that's the same one I found.
    Yes I did. Changed some settings in VCDS for the telephone and the canbus as per a thread on the VW Club SA forum. Link a few posts up. I don't think I changed anything with regards to media. Might have a look through it all again tomorrow.
    Mar 2014
    Melbourne, Vic
    This is my coding for the same unit, does yours match?
    9WZ Bluetooth install-1-jpg
    Jun 2015
    Willy, Victoria
    Hey mate so my coding didn't match. It was as per below.
    I've now changed it so that it matches yours but that made zero difference.
    I'm now a little worried that the problem may be my phone. I have an iPhone 6...
    I think I'll start a new thread in the audio & navigation forum.
    Mar 2014
    Melbourne, Vic
    Bit of a strange one and it wouldn't be the phone as I had a Iphone 6 at the time and now have a 7 and works fine with both
    Jun 2015
    Willy, Victoria
    Oh good. I really didn't want to change to an android phone. Thanks for your help so far!
