Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 9WZ Bluetooth install
    Jun 2015
    Willy, Victoria
    So today I (almost) finished installing a 9WZ module in my wagon. And before I go any further can I just say...
    WHAT. A. ****. Of a job!
    It took me the better part of 4 hours (a lot of which involved swearing) and it was one of the most irritating, annoying, infuriating, painful, frustrating jobs I have ever done on a car. I wouldn't wish that on my enemy.
    The main issue was trying to get the new wiring loom with those big connectors to fit in the tiny cavity behind the RNS so that the head unit could slide all the way back again. I eventually had half the dash off trying to get my hands in the back there to try and jiggle things around to get it all to fit.
    The module still isn't sitting fully under the seat because I don't have the tools to lift the seat rail so that I can thread the wiring under.
    I haven't managed to get my phone to connect yet but to be honest I couldn't be arsed right. That is future Dom's problem.
    Oh and did I mention that once I had put everything back together I had one spare panel screw!!! I looked everywhere but I could work out where it came from. I think it is from under the steering wheel somewhere because there was a "rattle" there when I took the dog to the park that I'm sure wasn't there this morning... Also future Dom's problem...
    Mar 2014
    Melbourne, Vic
    It is a bit of a pain to install.
    I used a coat hanger to draw the cable through to the cut outs in the carpet and had some success without too much hassle.
    Also found a spot for the large quad lock connectors to slot into and tuck away when pushing on the RNS. I can't imagine there being much space if you have more then one harness with additional quad lock connectors. 2 would be the max I think would fit without too much hassle
    Jun 2015
    Willy, Victoria
    Quote Originally Posted by rjt86 View Post
    I eventually got the quad locks to fit but it hurt a lot because my hands were too big to get in there.
    I'll give the coat hanger thing a go! I didn't think of that earlier...
    Mar 2014
    Melbourne, Vic
    It's a bit tight behind there but at least you got there!
    The coat hanger will help a lot. It should extend near the dash trim where it meets the carpet, therefore you can tape the cable to the coat hanger and guide it through
    Jun 2015
    Willy, Victoria
    And now my RVC isn't working... oh bother.
    Apr 2012
    Newcastle, NSW
    I used to complain about working on VW/Audi cars. Until i work on any others....
    2012 VW Passat Alltrack 125TDI
    2014 VW Touareg V8 TDI Rline
    I Have VCDS if needed in Newcastle area by anyone.
    i found if you cut the legs off the module it fits
    B6 Tdi Wagon - Reflex silver, heated memory leather, sunroof, 300k+
    MK7.5 Alltrack 132tsi Premium - Tornado Red, Sound & vision, Sport lux packs + retrofits
    Nov 2010
    I found installing my Bluetooth a breeze compared to installing my RVC!! I didn't have any issues with the headunit not sliding back. It was a little bit of a pain tracking the wiring through under the carpet to the cutout near where the unit sits but overall, not too bad. Isn't that strange that you've had a right royal ***** of a time installing!!!
    Jun 2015
    Willy, Victoria
    Quote Originally Posted by snerlo View Post
    Ya not sure if I was just being an idiot but it was really doing my head in. Anyway I'll have to pull it all apart again tomorrow to find out why the RVC isn't working. Will also sort out the wiring under the seat.
    Jun 2015
    Willy, Victoria
    So I made lots of progress yesterday...
    RVC working again - check
    It seems that the locking mechanism for the plug on the back of the RNS is broken. The little spring bit that locks the lever in place once installed has broken off. I just pushed it in a bit more and that seemed to work.
    Found where the extra panel screw belonged - check
    It was in behind the glovebox.
    Rattle on driver's side fixed - check
    I think it was the front cover over the instrument cluster. Wasn't clipped in properly...
    BT wiring loom fixed - check
    I bought a spline set and lifted the seat so that I could the loom fully under the carpet and through the cutout under the seat. It was so tight under there that this was the only way.
    I got the phone programmed on VCDS, as well setting up the voice commands, and have made a test call after pairing my phone. So far that all works really well and I'm really happy with the audio quality! My work colleague has an A3 and phone calls in his car sound ****house!
    The only thing left is to get the BT working for media. The button is there but it's still greyed out. I imagine it's another setting in VCDS?
    For anyone else looking to do this I found this excellent tutorial on the VW Club SA forum.
    https://vwclub.co.za/forum/viewtopic.php?t=116308
