Results 1 to 7 of 7
Thread: 4 Motion rear diff oil change?
    Dec 2014
    I've seen lots of references to the need to change both the DSG and Haldex oil & filter every 60,000 km or 4 years.
    However what about the rear diff on a 4 Motion? Should that oil be changed and if so how often?
    Any information greatly appreciated.
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
    Adelaide hills, SA
    I do mine and recommend every 30,000km. Those strapped for cash I'd suggest every 60,000km especially when they want to keep the car for a long time. Most VW diffs hold around 1L of oil, so it's not a big deal.
    Dec 2008
    Sydney/Canberra
    No service interval on it, however there's nothing stopping you from chaning it.
    Oil is nothing special, just full-synthetic 75W-90 gear oil.
    Dec 2014
    Thanks Transporter and Umai Naa!!. It sounds like an optional thing to give longevity every opportunity even though the old oil will probably look quite clean. I suppose it should be filled to the filler hole?
    Dec 2008
    Sydney/Canberra
    Yeah, pretty much.
    Main thing is to be 100% certain you're draining and filling through the correct plugs.
    Dec 2014
    Quote Originally Posted by Umai Naa!! View Post
    Thanks. You betcha. The Haldex wouldn't enjoy diff oil!!
    Jun 2011
    Yeah, pretty much.
    Is there some good clear diagrams on performing this change?
