I do mine and recommend every 30,000km. Those strapped for cash I'd suggest every 60,000km especially when they want to keep the car for a long time. Most VW diffs hold around 1L of oil, so it's not a big deal.
I've seen lots of references to the need to change both the DSG and Haldex oil & filter every 60,000 km or 4 years.
However what about the rear diff on a 4 Motion? Should that oil be changed and if so how often?
Any information greatly appreciated.
2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
No service interval on it, however there's nothing stopping you from chaning it.
Oil is nothing special, just full-synthetic 75W-90 gear oil.
Thanks Transporter and Umai Naa!!. It sounds like an optional thing to give longevity every opportunity even though the old oil will probably look quite clean. I suppose it should be filled to the filler hole?
Yeah, pretty much.
Main thing is to be 100% certain you're draining and filling through the correct plugs.
