Results 1 to 3 of 3
Thread: 3.2 FSI faults
    Dec 2015
    Warszawa Poland
    3.2 FSI faults
    Hi there. Do you have any ideas where to start to look for the source of below? Engine runs smooth and nice as usually... Thanks.
    Component and/or Version: P3.2-FSI-EU4 G00 1086
    Software Coding: 0000175
    Work Shop Code: WSC 00028 028 00001
    VCID: 62C182D4BDC5852E08-8036
    2 Faults Found:000373 - Fuel Trim; Bank 2
    P0175 - 008 - System Too Rich - MIL ON
    Freeze Frame:
    Fault Status: 11101000
    Fault Priority: 0
    Fault Frequency: 47
    Reset counter: 255
    Mileage: 242932 km
    Time Indication: 0
    Date: 2016.07.19
    Time: 06:57:13
    Freeze Frame:
    RPM: 609 /min
    Load: 32.9 %
    Speed: 0.0 km/h
    Temperature: 89.0°C
    Temperature: 33.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.589 V
    000370 - Fuel Trim; Bank 1
    P0172 - 008 - System Too Rich - MIL ON
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 41
    Reset counter: 255
    Mileage: 242932 km
    Time Indication: 0
    Date: 2016.07.19
    Time: 06:57:19
    Freeze Frame:
    RPM: 609 /min
    Load: 32.9 %
    Speed: 0.0 km/h
    Temperature: 89.0°C
    Temperature: 34.0°C
    Voltage: 13.589 V
    Any and every fault from VCDS should be googled and run back to the Wiki.
    16556/P0172/000370 - Ross-Tech Wiki
    It gives so much, makes me look good regularly.
    Check the fuel trims, probably block 032?
    Probably out by miles.
    Quote Originally Posted by adiaudi View Post
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 47
    Reset counter: 255
    Mileage: 242932 km
    Time Indication: 0
    Date: 2016.07.19
    Time: 06:57:13
    Freeze Frame:
    RPM: 609 /min
    Load: 32.9 %
    Speed: 0.0 km/h
    Temperature: 89.0°C
    Temperature: 33.0°C
    Voltage: 13.589 V
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 41
    Reset counter: 255
    Mileage: 242932 km
    Time Indication: 0
    Date: 2016.07.19
    Time: 06:57:19
    Freeze Frame:
    RPM: 609 /min
    Load: 32.9 %
    Speed: 0.0 km/h
    Temperature: 89.0°C
    Temperature: 34.0°C
    Voltage: 13.589 V
    Dec 2015
    Warszawa Poland
    Thx. I have red that Ross Tech already, just thought someone already went through such thing... Looks like I will not be able to fix it myself. Anyway I will let you know the result of fixing, may help in the future.
