Results 1 to 5 of 5
Thread: 09 R36 Steering wheel Retrofit help
    May 2021
    Sydney,NSW
    Question 09 R36 Steering wheel Retrofit help
    Hi team,
    I need some help with my 09 R36.
    I have recently swapped out my old 8 button steering wheel for a new 12 button steering wheel from a Golf mk6r. Everything works except for the horn. All the buttons work and light up as intended. My cruise control works, no lit up errors on the instrument cluster. I have swapped out the steering wheel control module for a AH revision one. G85 calibration successful. I just don't know why my horn does not work. Is it something to do with my coding or airbag harness/clock spring? Any advice would be appreciated.
    Thanks!
    Need airbag harness rev C or higher.
    If you already have that then you've unplugged the horn ring when installing the airbag.
    May 2021
    Sydney,NSW
    Thanks! I'll have a look at what I have tomorrow.
    May 2021
    Sydney,NSW
    I checked my airbag harness and discovered that I have a revision A harness. I'll get a rev c harness. Thanks again mate.
    May 2021
    Sydney,NSW
    Can confirm airbag harness revision c has fixed my horn problem
