To answer some common questions:
Does this suit my vehicle?
· Volkswagen Golf MK5 (1K): with red FIS / MFD.
· Volkswagen Golf MK6 (5K): with white and color FIS / MFD.
· Volkswagen Golf Plus MK5: with red FIS / MFD.
· Volkswagen Golf Plus MK6: with white and color FIS / MFD.
· Volkswagen EOS (1F): with red, white and color FIS / MFD.
· Volkswagen Scirocco (13): with red, white and color FIS / MFD.
· Volkswagen Jetta MK5 (1K): with red and white FIS / MFD.
· Volkswagen Jetta MK6 (5C): with red and white FIS / MFD.
· Volkswagen Passat (3C): with red FIS / MFD.
· Volkswagen Passat (36): with white and color FIS / MFD.
· Volkswagen Passat NMS (New Mid-size Sedan): with white and color FIS / MFD.
· Volkswagen Passat CC (35): with white and color FIS / MFD.
· Volkswagen Touran (1T): with red, white and color FIS / MFD.
· Volkswagen Tiguan (5N): with red, white and color FIS / MFD.
· Volkswagen Sharan (7N): with white and color FIS / MFD.
· Volkswagen Caddy (2K): with red full height FIS / MFD.
· Volkswagen Caddy (2C): with white and color full height FIS / MFD.
· Skoda Octavia II 2008 (1Z): with red FIS / MFD.
· Skoda Octavia II Facelift (1Z): with white and color FIS / MFD.
· Skoda Superb II (3T): with white and color FIS / MFD.
· Skoda Yeti: with white FIS / MFD.
· Skoda Fabia 2010 and onwards: with white FIS / MFD.
· Skoda Roomster: with white FIS / MFD.
· Skoda Rapid 2012 and onwards: with white FIS / MFD.
What can it do?
Ability to modify the number of flashes of intermittent comfort indicators.
· Automatic lowering of the passenger mirror after engage reverse gear as a parking aid.
· Activation of secret vehicle functions that until now only were possible with a diagnosis cable and special software.
· TV-Free in Motion function to play videos or TV in the navigation with the vehicle in motion for the enjoyment of passengers.
· Customizable steering wheel keys and windshield wiper lever.
· Modification of the sensitivity of the rain sensor.
· Modification of the sensitivity of the light sensor.
· Enable / Disable American DLR.
· Enabling / Disabling daytime running lights.
· Enabling / Disabling cornering/gyre aid lights (using fog lights).
· Enabling / Disabling second rear fog light (when bulb is installed).
· Enable / disable automatic doors lock from 15 km/h.
· Enable / disable automatic closing by rain.
· Enabling / Disabling one touch closing windows.
· Enable / Disable hazard warning in case of sudden braking.
Additional Features:
PolarFIS enable “A2DP”, What is this?
The Advanced Audio Distribution Profile is a Bluetooth profile that allows for the wireless transmission of stereo audio from an A2DP source (typically a phone or computer) to an A2DP receiver (a set of Bluetooth headphones or stereo system).
Such devices typically also support the AVRCP profile as well in order to allow for track selection and such.
A common misconception is that A2DP support is available on all Bluetooth 2.0 devices, which is not the case, and that A2DP is only available on Bluetooth 2.0 devices, which is also not true. A2DP support can exist in older versions of Bluetooth, it just was not commonly supported.
Battery drain function for RNS510 units
PolarBT solve one important problem detected in the newest RNS-510 firmwares (from 26xx), in cars that have assembled gateways prior to index K. This make that your battery have drain issues and get damaged.
With our device, you not will need to change your gateway for fix this problem, simply plugging in your vehicle PolarBT will solve this critical issue.
Package contains:
1 x PolarFIS device (main hardware)
1 x Connection cable (gateway)
1 x USB Data cable (for software updates, latest 4.8 was released Friday 4th September 2015).
