Results 1 to 2 of 2
Thread: VW Central - MQB (Golf 7, Passat B8, New Tiguan, Octavia mk3 etc) VCDS Tweaks
    Apr 2009
    A question we get asked a lot, 'So I've just bought a new car, what VCDS tweaks can I have done?'
    There are plenty of threads and information out there to explain how it is done. We have taken several online articles and our own internal notes and put them into categories for an easy understanding.
    Please note, depending on your model and year vehicle, not all tweaks may be available to you.
    If you have any questions or would like to know more, please send us an inbox message.
    VW Central Social Media Team
    Lighting
    Daytime Running Lights - turn off/on via media screen
    This enables a new menu option under 'Lights' on media screen to control DRLs
    Daytime Running Lights - turn off/on via handbrake
    DRLs turn off when the handbrake is engaged
    Daytime Running Lights - remain ON when turn signal "blinks"
    Daytime Running Lights - Dim when turn signal "blinks"*
    LED Number Plate - stop bulb out warning if you have retrofitted LED license plate lighting
    Coming Home Lights - leave the headlights on for a period of time after locking the car.
    Useful for exiting a dark garage etc
    "Blinkers" - change cycles. Adjust the number of indicator blinks when soft pressing the turn signals for a lane change
    Fog Lights - Combine with High Beam Lights
    Allow the fog lights to remain lit when engaging high beam
    Incandescent Tail Lights - add Brake function to inner lights
    Allow the inner tail lights (the ones located in the boot) to be illuminated when braking
    LED Tail Lights - add Brake function to inner lights
    LED Tail Lights - add "Pace-Car" indicators
    The inner and outer indicator lights flash out of phase rather than together somewhat like a pace car
    Halogen Headlights - add Counter blinking DRLs on turn signal (instead of "DRL Wink")
    Headlamp on the indicating side will blink out of phase with the indicator
    "Angel Eye" Headlight fittings- Illuminate Dot with switch in all positions
    "Angel Eye" Headlight fittings- DRL Wink
    Single Sided Parking Lights
    Driver Convenience
    TMC - enable live traffic information
    Rain closing
    Allows windows and sunroof to close on detection of rain by Rain Light Sensor if car is locked
    Disable stop/start
    Disables the Bluemotion Start/stop system
    Air Recirculation - automate
    Soundakator - adjust volume
    Discover media/pro "nag screens" - deactivate
    Seat Belt Warning - deactivate
    Lock/Unlock - alarm beep
    Lock/Unlock - acknowledgement without alarm horn fitted
    Ignition-on alarm when driver's door open - Disable
    Fan Speed Indicator - display on "auto" mode
    Window Comfort Opening/Closing with key-fob
    Enable WLAN on Discover Pro MIB1
    MIBII - Enable Off Road Display
    Instruments
    Needle Staging - When accessories are turned on, speedo and tacho needles sweep around the dial and back to 0
    Refuel Quantity - Displays remaining fuel quantity in litres
    Instrument cluster - Increase illumination during daylight
    Instrument cluster - Increase illumination of clock dials during daylight
    Genuine VW Parts Importer | Navigation | Bluetooth |
    Repairs | Lighting | Coding | Programming |Cameras
    Jul 2016
    Berry, NSW
    Can WLAN be enabled on a MIB11
