Results 1 to 2 of 2
Thread: Skoda Rapid Rain sensor not working
    Hi. I've installed the rain and headlight sensor for Skoda/rapid but I could not run the rain sensor. That option is unchecked in the menu. what should I do. can you help me.
    @DV52
    Tapatalk kullanarak iPhone aracılığıyla gönderildi
    Quote Originally Posted by MSE View Post
    @DV52
    MSF: OK If you have fitted an entirely new Rain/Light Sensor on the windshield, then you need to tell the CAN bus that it has to start communicating with the device. As you probably already know the RLS, RLHS, or RLHS is a slave module to the BCM (via a single LIN wire), so the software switch is in the module @ address hex09. Byte 6 > Bit 0-1 set to hex02 .....and if you have a rotary light switch with an "auto" position, also Byte 7> Enable Bit 5
