Took the car to A1 suspension and mechanical in tweed heads today to get the front end looked over. Passed with flying colours! Whoever buys this is getting a solid car. Bumpity bump bump.
I think it's time to part ways . Bought the car stock in 09 and its come a long way to end up like this.
Details are
My00 mk4 gti
Odo: 180XXX kms
Mod list
Engine
Custom Code stage 3 ECU
Garrett GT2871R .64ar (56 trim)
Bar-Tek T25 top mount cast exhaust manifold
IE forged connecting rods
Phenolic intake spacer
ARP head studs
ARP main studs
ARP crank pulley bolt
ARP cam pulley bolt
Custom 3" TIP
3" custom turbo back exhaust
Siemens 630cc fuel injectors @ 3bar
USRT billet injector cups
Genesis high flow intank fuel pump
044 Bosch fuel pump mounted in an 034 motorsports 1L surge tank
USRT fuel pump wiring harness
Enclosed k&n pod filter with stock positioned ICM
CTS fmic
Forge throttle body hose
3" maf
Forge 008 dv
034 billet pcv valve
Driveline
Dieselgeek sigma 5 short shift kit
ECS stage 1 clutch and 21lb SMF
ECS Dogbone mount
VF engineering motor and transmission mounts
02J rebuilt and strengthened by Neat gearboxes
Wavetrak TBD
Raxles v2.1b axles
Suspension-brakes-wheels
KW V1 coilovers
OEM R32 brake conversion. 334x32mm front. 256x19mm rear.
Poly strut top mounts
TT control arm bushes
Whiteline 24mm adjustable rear sway bar
Koya Drift teks 18x8.5 et30
Pirelli P1s 225-40-18
Exterior
Blacked out badges
Clear/smoked side indiators
+25kw worth of stickers
R32 replica front bumper
R32 replica side skirts
Seat Cupra R lip
ECS stubby antenna
Interior
Dual column pod with NewSouth boost and oil pressure gauges
Vent mounted Innovate wideband A/F guage
Headliner DIY re-trim
Rods, new piston rings and bearings were done at 151000km then again after my oil pump went at 155000kms. Engine has been rock solid since then. Oil changed every 5k using Penrite. Body is in great condition for its age. I've spent a lot on this car and I still love it so I'm not in any hurry to get rid of it but I kinda wouldn't mind a change.
Asking $11000, a little negotiable but not really. I've dropped well over $30k into this car not including the purchase price so whoever buys it will be getting quite a bargain.
Full build thread link in my signature
Some more pics for clicks
I'd like to add to Carlos comment's. I have had a fair bit of input in the car over the years.
For all the fearsome rep of the big turbo. Off boost I'd be happy to let my daughter drive it as it is very docile. Quite a Jekyll and Hyde car.
The suspension is pretty pleasant in the scenarios I have driven it, highway and suburbia. Much less aggressive than my polo. Yet still able to run quick on the track.
I think you could also get a Pizza or two thrown in if you ask nicely.
Id just like free pizza! GLWS Carlos your cars been a big inspiration for my build! Who ever buys this will be getting a great car!
