lovely looking gti, good luck with the sale mate...
82 model year (Sept 81 build date) 1.6 GTI, close ratio 5 speed with eager engine makes this a great driving combination. Originally delivered to Singapore and imported to Australia in 2006, she has never seen a salted road as all the UK delivered cars have. Matching numbers car with VW ‘birth certificate’ to authenticate the above. I have used the car as a daily at times during the 8 years I’ve looked after her with the focus on getting it reliable, she has never not got me home in 20,000 kms!
Engine
Head was rebuilt by PO with Schrick 40 x 35 valves (original 38 x 31)
Samco silicon hoses, new water pump
Rebuilt FI system including rebuilt WUR, new bosch pump, new injectors, new injector lines
New fuel tank
Genuine VW Windage tray
Replaced oil pump
Bodywork
Original rust-free fuel filler pipe taken back to bare metal, e-coated and painted
NOS grille and badge
New red grill surround
Paint is not perfect
Gearbox
Regularly changed oil, no 2nd gear crunch
Clutch cable bulkhead plate used, although there is no damaged or structural rust around the hole (preventive only)
New clutch cable
Suspension
Koni T/A (fronts are 2 years old) and Eibach springs
Superpro poly bushes all round (except engine mounts)
New steering rack to column boot
GTI Leather steering wheel
Interior
Dashboard replaced with perfect 93 cabriolet one, and recoloured by Bus’N’Bug in Melbourne
NOS gauge surround
Front door pockets are missing
Carpet is original but bare on the rear passenger side
Worn through driver’s upper bolster
Electrics
NOS fuse box
Period Blaupunkt M23 Cambridge cassette radio (this has been modified with rca pre-outs and a 3.5mm aux input that works instead if the cassette player when the tape is pushed in), electric aerial
Rebuilt front wiper mechanism with MK2 motor, ‘99’ relay for front intermittent wiper, ‘72’ relay for rear intermittent wiper
New bosch headlights (rewired on relays)
Period style VDO oil pressure, oil temp and battery voltage gauges (back lights wired into dash lights – so dims with dash lights)
Brakes
New rear brake pressure regulator
MK2 master cylinder, MK3 brake booster
Stainless Steel Braided Brake Hoses
Exhaust
New middle and rear sections (Ernst)
Feel free to contact if you want more details or to view - car is based in the Manly area of Brisbane.
Offers over $17k - I am not desperate to sell so please no low ballers
Cheers Gav
0four4nine 1nine13three2
Looks in reasonable nick.
Don't know about that price, but they are getting hard to find.
Shame about the sunroof, otherwise I may have had a closer look and tried to low ball you.
Friend of mine has a hard on for one of these, will show it to him in the morning and see if he is interested.
GL with the sale
Deposit received
