Awesome value for money! glws
My new MK1 Golf 75/6
Not engineered but all work done, sold with alloys with no tyres and steels with tyres.
7000
PM for more info.
Thanks
Mk1 Gti 81 2Dr
Mk2 Gti 88 2Dr
Mk4 R32 04
PM sent.
Body/interior
• 75/6 4 door Australian built swallow tail
• Engine bay painted in flipper blue
• New carpet (2 door carpet so does not fit correctly around rear seat base) you can get rear 4 door section i have spare carpet so you could make the section and attached it to the one that is fitted to cover the gap.
• New headlining
• Rear sun shade
• Rear seat excellent condition
• Front seats very good condition with some small tears
• New dash carpet
• Dash is cracked
• Radio removed coin tray fitted
• Dash printed circuit board re wired with new globes
• Modified roof rack-still not finished, one of the legs need to be welded as i re positioned it.
Engine
• New AUM engine running standard MK4 GTI ECU, with a immobliser defeat micro chip wired on to the K-LINE (chip can be reoved for security-not internal to ECU)
• AGU big port head 40,000km (STOCK K03)
• New rear main seal
• Polo GTI dual mass flywheel
• New clutch and pressure plate
• New release bearing
• New clutch slave cylinder
• New cambelt
• 20 valve engine conversion mounts with MK1 golf diesel bushes
• New fuel lines from tank to engine bay
• New fuel filter
• New diverter valve
• Qpeng 2.5 inch down pipe
• Power steering and Aircon removed and bracket modified
• New aux belt
• Custom wiring loom still running original Air mass, air temp, coolant temp, coils and output stages, injectors, turbo charge valve, lambda probe(new).
• Bosh 044 fuel pump
• Modified cambelt tensioner ( non-hydraulic)
• Custom Audi S3 intercooler
• New MK2 golf G60 RADITOR
• Slim line radiator fans X2
• All new vacuum lines
• Custom water hose’s
• Custom charge air hoses and pipes
• New Jetex exhaust and back box
Running gear
• 02J Mk4 golf gearbox
• Drive shaft modified to fit in original MK1 hubs
• New front wheel bearings
• New front hubs
• Audi A6 Girling 56 front brake callipers
• New Mk2 golf G6 front brake disc
• 02J gear cable selector
• Mk2 Golf G60 BBS RM with polished rims and new bolts
• Mk2 GTI Steel Rims
• New polly bushes all round (front and rear suspension)
• AVO competition suspension height and damper adjustable.
• Custom Hydraulic clutch pedal set up with wildwood master cylinder
• New MK1 cab strut top mounts
• New ball joints X2
• New track rod ends
• New inner track rods
• New steering rack boots
• New steering column boot
• MK2 golf GTI brake servo
• Mk2 GTI brake master cylinder
• New brake hoses front
Needs to be fixed
• Rear carpet section
• Rear tailgate upper lip had some rust so I have removed some of the lip and was getting round to have a new section welded in, due to this the roof lining cannot be pull tight (I will attach some photos when I next go down to the car.
• Engine fans run on the original thermo switch so they cut in and out a lot on hot days, not an issue but I was going to fit a timer relay to make the fan operational more stable. (Just me been anal).
• No surge tank just gravity feed from the fuel tank, works ok but ideally would need a surge tank if you was planning on lateral forces on the tank
• Oil pump wiring is the wrong way round due to the original oil switch from the Golf IV and MK1 dash, So the light is on all the time (light on mean good oil pressure, light go out means switch the thing off)
• No coolant/oil temp gauged fitted.
Currently not registered, will not be supply with plates.
Will not split.
Any questions please ask on this sale page as i cant answer the phone during the day. PM will be replayed to if and when i log on.
Thanks Gareth
Beautiful car buddy. You will regret it
Pm'd mate .
2001 black gti 18" tt rims ,kmacs and a big dent (daily until rego runs out and mk1 is painted )PHP Code:
mi
76 gls 3dr agu ( build in progress, )
77 gl parts car
Bump with answer on questions.
Thanks for the intrest
What's the new info you've added, I can't remember exactly what was and wasn't there before?
Sold pending inspection, thanks for the interest.
Wow I can't believe you were asking so little for it - I would've started nearer 10k - such a beautiful car, if you consider that someone just sold some BBS RMs in worse specs than yours for $2000+ and then all the conversion work too! Someone's got a bargain!
2019 132TSI Tiguan
2011 Audi S4 Wagon
1988 MK1 Caddy
2006 Polo GTI
