If you are interested in parting out some minor bits here and there - i.e., seat sport brace, forge rear brace - speak to me
Time to say say goodbye to my little polo, moving overseas due to unexpected circumstances.
Car is in perfect working order with no issue to fix, ride quality is a little harsher than standard due to mods.
The car has done ~147000km and has been trouble free for the past 8 years of ownership.
Fully serviced, no cheap fuel was ever allowed into the tank and always using good fuel additive.
It will be priced for a quick sell for now, but I might bring the price back up and take it slow if I can't sell it before I go.
I'll let go at $7500 for now, reasonable offers considered.
This car is track ready.
Can help arrange interstate transport at buyer's expense.
Mods list:
Tuned by myself, 181HP & 400NM at the flywheel(100HP & 239Nm standard)
ARL(PD150) head bolt
PD130/150 AL injectors
PD160 intake
Darkside Custom 80mm Alloy TIP Pipe
Darkside FMIC 57mm Hard Pipework Kit
Darkside EGR&ASV delete kit including cooler delete
PD160 turbo GT1749VB
THS Seat Ibiza FMIC
3 Bar MAP sensor
Turbo back 3' mild steel custom exhaust + 200 cell cat + rear straight through silencer
Ventilation for FMIC behind licence plate
PowerFlex Front sway bar bush
PowerFlex LCA front bush
PowerFlex Rear Beam Mounting Bush
PowerFlex Diesel(softer) Lower Engine Mount Large Bush
Superpro Anti Lift LCA rear bush
Superpro Steering rack bush
Vibra Technics Engine and Gearbox mounts
Bilstien B16 PSS9
K-mac strut top camber & castor adjustable
Eibach rear camber and toe shims
SEAT Sport MOMO front strut brace
Wiechers aluminium front subframe brace
Forge rear upper brace
UltraRacing rear lower brace
Whiteline rear sway bar kit 20mm
Ronal R42 16x7.5 5x100
Dunlop SP Sportmaxx 215/45R16 86 H
Polo GTI front steering knuckle with new bearings
Audi S3 front caliper + ATE 312mm disc + ATE ceramic pad
Bora V5 rear caliper + 256mm disc + ATE ceramic pad
Darkside SILENT G60 Single Mass Cast Flywheel & Clutch Kit
Redline MTL
Forge 350g "big knob" shift knob
Shorten shifter rod
Shifter cable bracket solid bush
Dieselgeek short shifter kit
ProVent200 catch can
Dash duel gauge with Newsouth EGT and boost
Original headlight blackened with HID Hi-Lo low beam projector
Replica Cup Edition rear wing(professionally colour painted)
Votex front valance(Comes with primer and Plasti dipped matte black)
Black rear lights with LEDs expect blinker, and fog & reverse light colour correction
ANS420 head unit + RVC
Cold white LED interior lights
OSIR ZERO SQUARE V2 for the old VW Key
Badgeless grille
Shark fin antenna(unprofessionally painted by me)
Added feature(not originally equipped)
-Bonnet strut
-Front fog light
-Headlight switch with front fog light control
-Centre sun visor
-Glove box light
-Wide angle blue tint heated side mirrors
-Rubber floor mat
-Leather Gaiter Perforated with Grey Stitch
-Leather Handbrake Gaiter
-Rear speakers
-Luggage component light
-Washer fluid level sensor
06 Polo TDi
08 9n3 Polo GTI
Mods: heaps
No worries mate. Both those items are pretty easy to remove if you change your mind.
Pictures updated
06 Polo TDi
