If you’re trying to sell your wheels and tyres, giving them a good thorough clean can help you fetch top dollar. With the help of Autoglym Clean wheels,Autoglym Custom Wheel cleaner and Autoglym Instant Tyre Dressing, it can help remove tough baked on dirt and brake dust from your wheels to help them look their best.
Before cleaning, make sure you determine the finishing of your wheels.
- Autoglym Clean Wheels is suitable for lacquered alloy, painted and plastic finishes.
- Autoglym Custom Wheel Cleaner is suitable for all wheel types including alloy, lacquered alloy, steel, chrome, painted, anodised and plastic finishes.
- If you have split rims these should be washed with Autoglym Bodywork Shampoo Conditioner.
Begin by working in a shaded environment, using a high pressure hose to blast off any easy to remove build ups.
Next you want to apply Autoglym Clean Wheels to the wheel surface and tyres, giving it a generous and even coating.
Using a wheel brush, agitate and work the solution, make sure to pay attention to small areas where it may be hard to reach (Autoglym Custom Wheel Cleaner can also be applied to tyre side walls to remove dirt and old dressings).
As the inner wheel barrel is less often cleaned, apply a generous amount of Custom Wheel Cleaner and let the solution work for a few minutes before brushing.
Once you’re happy with the result, simply hose off and check for any missed or tough to reach areas.
For extra detailing, shake and apply a light coat of Autoglym Instant Tyre Dressing to the sidewall of your wet or dry tyres. You can either allow the product to dry for a light sheen, or remove the excess with a clean microfibre for a matt finish.
Follow us
Autoglym Australia Website
Autoglym Australia Facebook
Autoglym Australia YouTube Channel
We are here to help you
If you require car care advice or you’re unsure on which Autoglym product to use for a specific task, please leave a comment below or head to Autoglym Australia for more information.
