Often overlooked, the boot jam, or hatch jam as shown in the images, seals the back of your car, protecting it from dirt, road grime, leaves and other nasties. Unless you clean your car thoroughly, it is an area often forgotten during the regular wash. Not only will dirt ruin the look of your car, but it can actually damage the paint over time if left unwashed.
The mix of particles on the dirt can scratch the surface of your clear coat allowing the bare metal to start oxidising, thus creating rust. So it’s ideal to wash your car’s seals regularly and thoroughly with Autoglym Engine & Machine Cleaner – though this product is predominately used for cleaning engines, it’s also great at attacking dirt and grime, and is 100% safe to use on seals and paintwork.
To begin, pop open the boot of your car and inspect the area around the jam and rubber seal. It is also a good time to also inspect the factory boot lining to make sure everything is intact, such as your car jack, tool kit and spare tyre. Remove any leaves that are trapped by hand or with an Autoglym Hi-Tech Wheel Brush.
Then, simply spray Autoglym Engine & Machine Cleaner around the boot jam and seals; do not spray the cleaner onto the underside of the boot lid, use the brush to carry the cleaner onto the edge of the panel edges and agitate any visible dirt to help loosen tough build ups.
To remove the cleaning solution, it is ideal to close the boot lid up to the first click, using a jet hose, point the away from the car to avoid splash back and hose off any cleaning solution.
Finish off by wiping and drying the area with a damp Autoglym Hi-tech Microfiber Cloth to remove any remaining dirt.
For a complete care, spray Autoglym Vinyl & Rubber Care onto a Perfect Polishing Cloth and apply to the rubber trim around your car to give the rubber seal a glossy shine while creating a protective coating.
To find out more information on any of the products mentioned, head over to Autoglym Australia.
Follow us
Autoglym Australia Website
Autoglym Australia Facebook
Autoglym Australia YouTube
We are here to help you
If you require car care advice or you're unsure on which Autoglym product to use for a specific task, please leave a comment below or head to Autoglym Australia for more information.
