Active Insect Remover safely breaks down and removes insect remains from paintwork, glass, number plates and lights. Insect remains spoil the look of your car and can cause damage to the paintwork.
Active Insect Remover is a simple spray on, wipe off product, allowing you to remove squashed insects on the go. The rich foam soaks the remains and gently loosens them from the vehicle.
Keep a bottle in your boot to remove insect residue as required, or use as a pre-soak spray to loosen stubborn remains before a full body wash with Bodywork Shampoo Conditioner.
Pro Tip: This is a great preventative maintenance product. If ignored, insect remains can cause marks which may require polishing or more serious rectification work.
See the video below on how to use Active Insect Remover and how effective it can be in removing insect remains from your paintwork.
For more information on Autoglym Active Insect Remover or other Autoglym products, visit the website at http://www.autoglym.com.au/
Links:
Autoglym Facebook - https://www.facebook.com/AutoglymAustralia
Autoglym YouTube - https://www.youtube.com/user/autoglym
