Originally Posted by
Maverick
"Opti-Coat is not a nano particle, it is rather a pre-polymer that cross links and forms a continuous film on the surfaces it is applied to, similar to a single component isocyanate that forms a clear coat finish. Opti-Coat also reacts with the substrate that it is applied to so it will not delaminate. Nano particles are sub micron particles that are created by controlled reactions or by breaking down larger particles. They do not react or form bonds.
As far as the durability of Opti-Coat, it is similar to urethane clears. It will not wash away or break down, however, you can polish it over time ! The hardness starts at 6-7 but will increase over time to 9H as it is exposed to heat. Coat is based on a resin pre-polymer that we manufacture and once it is applied, it cross links and reacts with urethane and other clear coat paints. Opti-Coat has better chemical resistance, scratch & mar resistance, and release properties than any automotive coating in use. This coating like a regular clear coat lasts indefinitely unless it is removed by polishing, sanding, or paint removers.”
Where do I start with this, the whole two paragraphs are just full of marketing BS.
