Results 1 to 6 of 6
Thread: White spot on car after washing
    Dec 2013
    Western Australia
    How do you remove these I've noticed a few time after washing the car I get these on the paintwork and bloody hard to remove ??? Thanks
    Apr 2013
    Chadstone, Victoria
    What sort of white mark? Like water spots where water has dried onto the paint?
    Run through your wash process quickly to give us an idea what you are doing
    Have a picture?
    Dec 2013
    Western Australia
    Probably a water mark although I do use a chamois but may sometimes miss a spot
    Apr 2013
    Chadstone, Victoria
    You are better off with a waffle weave towel rather than a chamois. Keeping to the site sponsers, I'd recommend (and personally use) one of these Car Care Products / Mint / Car Accessories / Cloths & Chamois / Microfibre Drying Towel Waffle Weave Extra Large
    It will dry better than a chamois, and be less likely to leave micro scratches in the process.
    As far as getting rid of your water marks, somehthing like Car Care Products / P21S / Exterior / Surface Prep / Gloss Enhancing Paint Cleanser is probably a good bet.
    And to avoid them in the future, it's a good idea to use a quick detailer or even spray wax when you wash your car. There are dozens of QD's out there, but I've used this zaino one in the past Car Care Products / Zaino / Exterior / Quick Detailing Sprays / Z6 Ultra Clean Gloss Enhancer Spray
    Dec 2012
    Sutherland Shire, Sydney
    White spots are normally bird ****e - lol
    Water spots are caused by dissolved minerals in water, when water evaporates the minerals stays.
    Apart from getting the water off the car ASAP,
    The cheapest and easiest method is to use just ordinary vinegar.
    I have a 5+ year old Charcoal colored Mazda SP23 with lots of water marks on the roof due to lack of care and sealant in the early years
    Once the water marks etch deep into or through the clear coat you're a bit stuffed
    I used PS21 and that didn't help with my (advanced) problem
    ScratchX helped however
