Results 1 to 10 of 12
Thread: Vinyl trim peeling paint.....any solutions ?
    Aug 2008
    A few pictures of the peeling paint??.
    2014 T5.1 Multivan Tuned by Pendle Performance Australia
    Castle Hill (Sydney)
    I would try using a heatgun or hairdryer to see if you can get the rest of it to peel. If not go and see a trimmer and get it resprayed
    Jun 2008
    South Coast N.S.W.
    The heat gun may work but you will have to be careful not to give it too much heat as you may distort the plastic or it may have the opposite effect and bake it on as well. I just did a quick Google search on the subject of removing paint from plastic and a couple of suggestions that I found on a site about Model Cars are to soak stuff in methylated spirit or they are also using a product called Simple Green which is an all purpose concentrated cleaner / degreaser and is available from Bunnings stores for between $10 - $20 for a 500ml container. It is supposed to work really well for removing paint from intricate plastic model parts so it should be safe enough to use on your plastic trim. A toothbrush or stiff scrubbing brush will probably be required as well to do the job. Keep us posted on how it goes.
    Russ
    Russ
    2005 Subaru Outback 3.0 R Premium
    the only problem i can see with that is it may remove the underlying paint as well.
    Keep the heatgun on low and at least 30cm away from the lastic. you will know if its getting to hot. Just heat it lightly as your pulling it away
    Aug 2008
    I will give it a go and let you know my results. Got a busy week this week so will probably be next weekend before I can have a go at it.
    Jun 2008
    South Coast N.S.W.
    Quote Originally Posted by DMS_Dan View Post
    That all depends on whether it has another coat underneath the darker colour that is peeling. The light grey that is showing under the peeling paint may well be the colour of the plastic as it came from the mould. You should be able to determine that by looking at the colour on the flip side of the trim. I don't really know why they needed to paint the trim in the first place cause there's not a lot of difference between the two colours anyway.
    Russ
    Russ
