yeah well... that's what the Duragloss Aquawax does, but which has been "not recommended"![]()
You can use the nanolex spray sealant to top it up or you can try something like poorboys quick wax plus which will add wax and therefore leave a different finish. Adding wax on top of sealant is not only a good way to keep the sealant on there longer but also a good way to add more depth and a different shine to your paint. Just depends on the actual paint and your preference on the finish.
dopey,
As mentioned, you are mixing a polymer style spray over a nanotechnology product. If you were adding wax to a polymer/synthetic coating that would be fine however with Nanolex their genuinely is no point. You will change the look yes, you however also will change the properties and durability/longevity of the product as well.
A nano product provides honestly probably the best protection possibly you can get. If you want to go down the Polymer line maybe try Zaino, Duragloss, Wolfs, Opti or another Polymer Sealant style product.
Car Care Products Australia
www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
Sydney - Brisbane - Melbourne
