To the comments of wfdtamar, we have quite a lot of customer reviews and not all make them through. Whether negative or positive we always put them through and we also contact customers after any reviews full stop (thats negative or positive again) to see why they reviewed it as such or even to why it is not working up to their expectations.
bottomscratcher is on the right line, it is alkaline and if you want to de-wax your car or de-seal if you wish its a great way as eventually it will start to diminish the coating you have and is probably recommend to top up afterwards.
Sometimes it is best to find out a little more into the product as sometimes even professionals may not be aware or assume they are using something that is good when yes its good but is it the right product for you vs the professional who could be using it for a 'different use'.
Car Care Products Australia
www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
Sydney - Brisbane - Melbourne
I recently purchased one of these snow foam lancers cos they look great, but I'm having a bit of trouble with it.
CCP didn't have any Autobrite snow foam solution available, so I purchased the recommended 1Z Exclusiv Gloss Shampoo instead. I mixed one capful with the foam lancer bottle filled with water and attached it to a Karcher K2.180 gurney. I dialled the foam lancer all the way down (turned the knob clockwise as far as it would go, then backed off a bit) and adjusted the nozzle to give an even spray.
The stuff isn't foaming up for meIt's really watery and slides straight off my car (I've got it sealed with Duragloss sealant and wax). I know the sealant and wax will make it harder for it to stick, but right now it's got pretty much the same consistency as water.
What am I doing wrong? Maybe I'm mixing too much shampoo with too little water?
Just continue experimenting with the foam mixer on the lance. CCP would've sold you the right stuff. Heck, even Meguiars NXT foams up a treat.....
MK6 MY10 Golf GTI, 5dr Manual, Carbon Steel, Detroits, Tint
T6 MY06 Peugeot 307 HDi Touring, Manual, Iron Grey, Tint
Foamy vengeance
Got my Autobright foam lance on Friday, using Duragloss 901. I guess my expectations were to high, the cleaning was pretty poor. It did soften the crud so the karcher got it off ok. Took a bit of experimenting to get the right foam out of the lance.
I'll wait and see what the Autobright stuff is like when it is back in stock.
1979 Mk1 Golf 2door (Under construction)
1994 Mk3 Golf VR6T, Autronic SM4, GT30r, Peloquin, 288mm Brakes, B&G coilovers
2000 Audi S4 Imola Wagon, Stage 3, J-fonz tune, F21's, ER SMIC, 034 DP's, JHM DTS, JHM Trio Short Shift, 350mm Brembo 6-pot, ABT coilovers, BBS CH, RNS-E, FBSW, Alpha 2.5 cat back
I think everyone forgets and doesn't realise it is not a "cleaning" solution. It is to help lift the dirt off slash pre-soak to remove excess dirt from the car before you wash.
Trying to make things for you as touchless as possibly when it comes down to wiping over with a mitt so you do not scratch up the paint.
Autobrite is the best
MY12 Golf R | 5 Dr | Candy White | DSG | 19"Black Talladegas | ACC | RNS510 SATNAV | Sunroof | RVC | BT | MDI
Ordered - 28/02/12 | Collected - 14/03/12
So I was looking into the Snow foam lance independantly of this forum and was pretty set on getting one from an online random UK seller (or from the US) but after reading this entire thread I am so impressed with CCP's atitude and response to posts in this thread that I would rather spend the extra $20 odd dollars to keep an Australian company in business who has shown such decorum.
I'll just need them to recommend foam etc, etc.
Just place my first order with CCP & ended up getting a snow foam lance - they're on sale for $100, hard to resist! Now I need to go to Bunnings & buy a Gerni![]()
2006 MkV 2.0TDI -> 2005 MkV GTI -> 2008 MkV R32 -> 2013 Polo 77TSI + 2016 Mk7 Golf R Wagon
