Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: small splash guard things...
    Quote Originally Posted by jlswadling View Post
    Well thats good to know aswell ope, i was refering to the ones on tarmac, the mini mud flaps!!! but now that we've been discussing these other parts that go with the Golf R 19" wheels, ill probs need those as well cause of my 18x8.5 wheels.
    yes that is correct - only the Golf R's with the optional 19" wheels have these little plastic guard extensions front and rear. If the car is not optioned with the 19" wheels (standard rims are 18" in the same shape/style) then the car will not have the plastic extensions fitted.
    As for the Tarmac mini mudflaps, i got a set of these recently. For my liking they stick out too far from the guards and ruin the lines of the car, so i drilled new mounting holes on mine to raise them up a little and pull them in a little. So now they stick out about 1.5cm from the guard, and hang down underneath the side skirt about 5cm. They most likely wont do as good of a job preventing stone chips now, but they do look a lot more discreet (basically unnoticeable).
    Erskineville, NSW
    you can buy Golf mudspats on Aliexpress & ebay for about $15-$25/set (f&R). There are 2 types - a short & long. maybe they suit what you are after?
    Aug 2013
    North Booval
    Cheers brad. Ill check them out aswell !!
    Nov 2010
    Burpengary, Queensland
    PM sent
    Nov 2010
    As usual,Lucas is always ready to offer help wherever he can, he has done so for me heaps of times. Thanks Lucas.
    BTW these pics are not of his car. I doubt that his has ever been this dirty lol
    Info and pics below are showing these little extensions on a Golf R, but i assume this is what the OP is trying to explain.
    Bold-Sport.com :: Golf R Plastic guard/ Fender extensions - Set of 4
    Part Numbers:
    Drivers Side Front/Front Right: 5K0807824B
    Passenger Side Front/Front Left: 5K0807823B
    Drivers Side Rear/Rear Right: 5K0807834
    Passenger Side Rear/Rear Left: 5K0807833
    I lost my driver side rear/rear right one (Part # 5K0807834) and ordered a new one through VW for $44. So they are not cheap.
    Some random photos from the interwebs to be clear on what parts I am talking about:
    Aug 2013
    North Booval
    Iv ordered some of these wheel arch extenders... cheers Lucas. There not cheap... but its better then gettin a defect written up !! And cheers brian. Making those mudspats up will be a good lil project over xmas. Ill be lookin forward to the next meet up in Jan
    Aug 2013
    North Booval
    Hey Lucas_R
    I ended up getting those parts u mentioned above from vw. The back ones fit fine. But the front ones dont because I got my guards rolled. I was wondering if u also had urs rolled or u had a "work around". I could screw it in. But with the edge rolled. Theres no longer a lip for those parts to hold onto... except for that adhesive tape which I dont wanna rely on..
    Any thoughts? Tips?
    Kind regards
    Jono
    ^ my guards are 100% stock (not rolled) so mine fit fine. You may need to use some adhesive (Sikaflex or similar) to secure your front ones.
    Aug 2013
    North Booval
    Fair enough mate. Cheers for that
