Originally Posted by
snoopin99
Yeh just tried the quick lock/unlock idea, didn't work. Need to get the trim off but while the door is still closed, going to be tricky! Any other ideas?
Pearce, will check that out once i get the bugger open!
If the Golf doors are the same as a Passat you may have fun as after you get the trim off there is a metal skin inside that that is riveted in and looked pretty hard to remove. I was only fixing rattles so didnt investigate further
