99% sure vw dont sell them seperate to the belt....scrap yard?......VDUB...
Hi, Where can one get the plastic buttons on the seat belt that stops the the buckle from dropping to the ground?
I have spoken to Repco and they know exactly what I'm after but do not sell them.
Cheers.
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
scrap yard will not do - they are a one use item. bring 2 parts of button together (pin and button) then join by melting the pin.
i have found them on ebay but trying local 1st.
People who sell webbing can supply a plastic piece that can be fitted to the belt that can be used as a stop. It is a bit like an S with the belt going under and over. It has to be soft as it can bear against you.
Failing that try a special seat belt manufacturer. They have to provide these things when they make a custom belt. These are used for wheelchair belts and the like.
