How much do you want to spend? and how much sanding are you doing/what purpose is it for (ie respray, defect removal, detailing etc?)
Well guys i'm basically fed up with hand sanding my whole car...wondering what electric or air tools i could buy to get the job done faster and for it to still look fantastic?
belt, orbital? and what grit paper to use.
Cheers guys
Orbital sanders rock! You will almost certainly spend several times the origanl outlay of the sander on sanding pads but they are definately a head above conventional sanding. You'll also get a more consistent finish with an orbital but it takes a bit of practice to get it right, but it does remove alot of the initial hard work of sanding.
80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
For that budget just buy the cheapest 1/3 sheet orbital sander you can from Bunnings and run it 'till it dies. Then buy another one.
Use 80 grit freecut for shaping bog and removing paint. Work your way up to 320 free cut and spray your primer surfacer over that. Wet sand the primer by hand starting with 800 wet & dry. Working up to 1200 wet & dry.
FYI Freecut is the white sandpaper, it doesn't clog up like the normal stuff you'd use on furniture. Wet and dry is dark grey and is as you'd expect waterproof.
Unless you already have a massive compressor I wouldn't bother with the air tools. If you do a random orbital sander is pretty versatile. You can also use air sanders for wet sanding. (Electric sanders don't like being dipped in the bucket of water much.)
Happy sanding!
Pete
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Get the one with the "triangular" shaped head so you can get into nooks and crannies as well as use it to sand an edge, much easier to get into places with.
Ozito tools FTW!
And a twelve month warranty means that if you manage to burn it out you get a new one![]()
As the boy's have said, an "orbital" will remove the material at a faster rate, saving you time ...
I purchased one of these several months ago, not cheap by any means but i have no air in the workshop. Bonus with this machine is you can use the larger 6 mm orbit to remove more material than the smaller 3 mm orbit.
http://www.metabo.com.au/Product-cat...c90cd5b.0.html
For the budget, you prob wont get any better than the 1/3 sheet sander as Pete has mentioned. unless you can find a rotary orbital second hand.
Basically sanding sucks, faster you get it done, the faster you can get onto the good ****z...![]()
Lots of MK 1 Scirocco's...
Cheers,
Grant...
Yeah i was going to suggest the Festool rotex. I have one them. They are awesome!! It has the bonus of being a forced rotation, random orbital and a polisher. It will sand a car SO FAST!
Slightly above budget at $800 though lol
