Results 1 to 9 of 9
Thread: Rattle can clear coat
    Gold Coast
    Need a bit of advice. I am in the process of re-furbing a set of wheels and i have painted them with 3 coats of black enamel paint. It looks good so far but I want the paint to look a little 'deeper' so i was gonna do a coupe of coats of clear.
    I've never used clear coat before so are there any does & dont's or pitfalls i need to look out for.I'm no pro & i'll be using rattle cans. Good idea?
    Jan 2009
    blankedy
    quality paint, warm the can first (stick can in bucket of warm water).
    Gold Coast
    Good tip, does that apply to all paint?
    Feb 2008
    mOOROOLBARK
    get a pro to do it in 2 pack the can stuff isnt as durable
    i done my front bumper in acrylic and then toped it with pressure pack clear coat
    it looked really good but didnt last very long
    Gold Coast
    Quote Originally Posted by mk3pete View Post
    Really. Might not bother then if thats the case.
    Jan 2010
    Springwood
    I find clear coat is a bit tricky to use
    if you lay it on too quick, or it's too humid, it can go milky.
    if you don't prep properly, it can craze
    might be worth getting a spray shop to quote, if you want a bit more protection and depth.
    Gold Coast
    Quote Originally Posted by Mr_Bob View Post
    Thats kind of what i was expecting. I used a clear primer for when doing some plastic bits and that was a pain to use. As i am in QLD humidity will be a problem & last thing i want is a bad finish.
    Might just go in the too hard basket.
    Cheers for the advice fellas.
    Castle Hill (Sydney)
    have you thought of powder coating? Its relatively cheap. Most guys i speak to end up paying about $50 a rim at most.
    Gold Coast
    Quote Originally Posted by DMS_Dan View Post
    I don't know if they can be powder coated, its only a few sections that are being painted. The detail is staying polished.
    I'm thinking of going the other way now anyone used crackle finish paint?
