you can rebuild the spaces with the old grille bits... get some Actylic Liquid solvent. Keep some plastic grille shavings and melt it up with the solvent then use it with solvent to glue in small bits and backing strips to build up the V gaps.
sand lightly with fine grade sandpaper or wet and dry... then spray with Vinyl paint... thats waht I did to mine and it looks OEM.
Hacked mine up for Hella LED DRL's
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
