Check out what I did with my cousin-in-law's Passat: http://rayray086.blogspot.com/2008/0...refurbish.html
Some adjustments since the last time I did it - try starting out with 600/800 grit sandpaper and wet sand. Do this up to 2000 grit. The more time you spend sanding and the higher the grit you finish up with, the clearer your results after polishing. Would be best to use an orbital for polishing too. Hand polishing just doesn't cut it.
