Results 11 to 20 of 25
Thread: Polishing Headlights and Glass
    Sep 2008
    bne.qld.au
    Finally got some 'Before & Afters' boys...
    Before: You can see the cloudy discolouration and pitting across the top of the plastic lens
    After: not a bad effort considering it was just WD sandpaper and polish
    Sep 2008
    bne.qld.au
    OK, just to show you what a bit of patience and hard work can achieve, I did the headlight lenses on my Dad's Bora 2.0 today.
    If I can get these results on a lens this badly weathered and discoloured, then anything's possible!
    Dad's Bora. Shiny.
    The Bora's headlights. Not so shiny.
    Driver's side:
    Passenger side:
    I went for pretty much the same method, using 220 > 360 > 800 WD sandpaper, with the final pass using superfine 1500 WD emery paper.
    Washed and dried, finished off with #2 cutting compound on an open weave cloth, followed by Plast-X then some light liquid polish.
    Although they're not perfect, transformation would be an understatement.
    Sep 2007
    niiiiiiiiiiice!!! top work
    87' MK2 GTI
    13' MK7 TDI
    Jan 2007
    Fantastic job, I just got some Mother's plastic polish, I'll try it out on a B5 Passat over the holidays...
    Mar 2007
    That's a pretty stunning achievement ... looks great.
    Dave
    Sep 2006
    West Sydney
    Woww!! That looks MUCH better than the before. Just wondering, can you wetsand with emery sandpaper?
    Sep 2008
    bne.qld.au
    Quote Originally Posted by rayray086 View Post
    I did?
    I actually did a very gentle first pass with 60 grit sandpaper just to loosen everything and get all the crap off the lenses. That stuff is hardcore so be careful if you intend to do it, because it'll take chunks out of the paint.
    I wrapped the emery paper around a sanding block because it is so fine, and just started dry sanding. But I found that if I wet the lens (as opposed to the paper) it worked just as well. So yes, the emery paper became wet so technically I wasn't WD sanding, but still... the results speak for themselves.
    I didn't think lenses that bad would turn out as well as they did?
    Quote Originally Posted by Golf Houso View Post
    Plastic polish is pretty good for any light marks or small scratches you may have, but something this caked needed some heavy duty treatment.
    I found that Plast-X was great for finishing it off and buffing the lighter swirls once I'd finished sanding the h3ll out of those lenses
    Sep 2006
    West Sydney
    Sorry, I only assumed you wetsanded with emery sandpaper cos of the soapy water in the pics!
    Sep 2008
    bne.qld.au
    You make a good point, as I actually soaked the other papers in the soapy bucket, whereas I didn't soak the emery paper.
    Getting the emery paper wet didn't seem to effect the result in any way, although I'm not sure if keeping it completely dry may have made for a better result?
    Castle Hill (Sydney)
    may i ask why 1500 emery paper and not say 2000 wet/dry?
