Most shops would mask up the mouldings, sand back the clear in and around that area so none is flaking off, go over it with a grey scotch pad to the top/right side of the door, spray on clear then and use blending thinners to blend in the new clear to the old clear so you don't get a line. That would be the easiest, fastest and cheapest way of doing it.
You can get a decent medium solids clear kit for around $120-160 bucks, I don't know what temp you will be spraying in but keep that in mind when selecting the hardner for the kit and as long as you take your time prepping the area, don't spray loads of clear on as two coats is fine and is all a shop will generally do, wear a mask, yes make sure you wear a mask trust me I have several spray painting friends who are as dense as they come now because they don't wear masks when no one is watching, you really can't go wrong.... famous last words![]()
