Results 1 to 10 of 12
Thread: Ouch!
    Sunshine coast
    Ouch!
    Had a rather unpleasant meeting with a triton a couple of days ago. I was backing out, slowly. Then the female driver decided to do the same. Even if the sensors went off and I stopped the car, I couldn't prevent her from backing into me.
    That particular parking sensor still seems to work.
    Edit: It's a passat wagon.
    132TSI Tiguan Allspace
    Jun 2009
    Let us know who you decide to go with for repairs and if you think the cost is appropriate.
    Jan 2013
    Brisbane, QLD.
    Assuming you both are accepting fault and paying for your own repairs each?
    Sunshine coast
    Yes it's really hard to prove I was at a standstill when she hit me. $575 excess.
    Sunshine coast
    Took off the bumper last night, there's a small internal dent, with some paint coming off where's there's some foamy seal covering a weld. Wondering if it needs to be sealed up with something?
    Otherwise thinking a panel beater might get the bumper back into shape fairly cheaply?
    Jun 2011
    Sydney NSW
    If the ding is not visible, then there is little to be gained by getting a panel beater to beat it out. Trying to make something concealed look perfect could see you exposing other issues and that will end up costing more.
    As for the seal, clean it out and use some neutral cure silicone sealant to make sure that water cannot get in and cause damage.
    Sunshine coast
    sorry, was thinking about the dent in the bumper itself, if it would come out easily.
    Pacific Paradise QLD
    Quote Originally Posted by iampivot View Post
    If its creased probably not Got a Toyota bumper popped back out but had no sharp edges in the bump Still was a bit knarly.
    Jun 2011
    Sydney NSW
    For the bumper itself, the problem is that the plastic will have stretched and so even when popped back out will be a little wrinkled.
    Bumper reconditioners do use appropriate heat as some plastics have "memory" and will shrink back. If you have resolved to get a new bumper, then you could try pushing it back out and then applying some heat via a hair dryer and see if that helps shrink back. If it does not work, then you were going to get a new bumper anyway
    Dont know about the Passat bumper price but a few years ago a Berlina front bumper was about $380 and $250 to paint it So might pay to not claim and fix it yourself
