I'm not looking for complete removal as there is no way to do that without reducing the minimum clearcoat thickness (the valleys between the peaks of the peel). The Carpro denim and velvet pads look like a good option to reduce the orange peel effect
Regular polishing won't do the job as the foam, wool or microfibers will cut into the valleys as well as the peaks, reducing the thickness of the clearcoat without greatly affecting the texture (it will reduce it a bit if the texture is particularly rough but you get diminishing returns as the peel peaks round off)
Anyway, when I have time, I'm going to try and find a practise panel and learn how to use the Carpro pads.
Resident grumpy old fart
