Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Orange peel removal or reduction?
    Oct 2010
    Melbourne, VIC
    My recent foray into paint correction had made me appreciate just how much orange peel is present on my car, even on panels that have never been damaged (ie most of them)
    Is wet sanding with a block the only means to get rid of this factory finish effect ?
    Or is there a combination of polisher (preferably DA), pad and compound that can effectively remove or at least reduce the orange peel?
    Resident grumpy old fart
    Feb 2009
    Please Enter Location
    Yes !
    Lot of work to do the whole car.
    Why not get the texture of your repair the same
    Oct 2010
    Melbourne, VIC
    I recently found these pads by Carpro - CarPro 3000grit Velvet Orange Peel Pad 135mm and CarPro 2000grit Denim Orange Peel Pad 80/100mm
    Has anyone had personal experience with these? Some reviews I've found are are positive.
    Mar 2010
    Total removal of orange peel is usually reserved for show cars because it leaves you with very little clear coat and shows every little blemish. Peel removal also limits the amount of polishing you can (and inevitably will need to) do. The most important thing is you need to know exactly how much clear coat you have to play with as you will be removing at least 5-10um of clear coat. The upside is, it looks utterly awesome.
    The pads you mentioned are good but very aggressive. I would only reccomend them to be used by someone who has plenty of experience in polishing. It would be very easy to strike through with those pads.
    To give you an idea on the steps involved in peel removal, they are:
    Sand with 1500grit
    Sand with 3000grit (follow with 5000 or 6000 if you can find it)
    Full correction with compound (eg: Menz FG500) and cutting pad
    Polish with medium grade polish (eg: Menz PF2500) and polishing pad
    Polish with finishing polish (eg: Menz 4000) and finishing pad
    To finish it off I would strongly reccomend a coating such as CQuartz, 22PLE, or even Opticote.
    08 Golf GTI - SOLD
    Jun 2008
    melbourne
    Quote Originally Posted by kaanage View Post
    I would highly recommend you invest in a paint thickness gauge before you think about wetsanding.
    The last thing you want to do is strike through.
    White Scirocco R
    White MK3 Golf 2dr
    White Caddy (Work Van)
    Oct 2010
    Melbourne, VIC
    I wouldn't expect to get my car dead flat like a show car but it would be nice to scrape down the peaks halfway to the valleys - I reckon that would make the paintwork look so much better (stupid dark paint )
    All those steps are why I asked if there was an alternative as I'd be sure to stuff up the sanding at some point and scratch through the clearcoat. I was hoping that with a DA and the right pad, I could do it more safely - I may try to find a panel from a wreckers with orange peel and get one of the softer velvet pads to experiment with but the missus might think I've totally lost the plot
    Thanks for the pro perspective - always best to hear from the guys who've been there, done that.
    Quote Originally Posted by Silver dub View Post
    If it had to be wet sanding, then I'd live with the peel
    Jul 2012
    Quote Originally Posted by Wolfgang View Post
    Sand with 1500grit
    What a great response!!
    I will add, stress the point that it really is for show cars, as they have been resprayed with wetsanding in mind, and allow for it in adding extra clear.
    Also bear in mind, that if it is a daily driver it will inevitably get marred again and like Wolfy said, you won't have much clear coat left to play with. i do agree that it looks amazing, but practically, unless the car only comes out for shows it's not worth it.
    But then that is only my perspective.
    Dec 2007
    How would you get rid of the orange peel in the base coat by sanding the clear coat?
    2008 Blue Graphite GTI DSG with Latte leather. SOLD 4/9/2024
    2023 T-ROC R - Sunroof, Black Pack, Beats Audio
    Apr 2013
    Chadstone, Victoria
    What you are trying to do (which it sounds like you already know), is remove the textured top part of the clear. So yes, it is usually done by wet-sanding it smooth and then polishing back to a shine.
    You say you want to avoid sanding? It is possible to flatten the paint with any abraisive polish alone, but you can expect to spend HOURS on each panel if you want to do it the slow way. Not that it is going to be a weekend job even if you wet-sand. I've never done a whole car, but I'd say 40+ hours of rubbing and polishing
    I'm with everyone else on this though, save flat paint for the show cars. The slightest mark will show up on your car, and you will be spending every weekend polishing them out, which will very soon leave you with no clear left and needing a paint job. Then the process starts again.
    Oct 2012
    Quote Originally Posted by QBDentFree View Post
    Hey mate, out of interest, how much time would one have to put in just to flatten out some dodgy clearcoat work on a bonnet? I don't want a flat showcar finish but rather bringing it to factory finish at least. It's just like they didn't take care when spraying it so the texture of the clear is not only bumpy but almost rough....
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
