Finally! We have released a super light Rotary Buffing Machine with soft start!
Available on its own here, or in a Kit with Pads & Polishers.
Originally Posted by Car Care Products dot com dot au
We have now taken Flitz on board a few weeks back.
Flitz provide an easy solution for wheel buffing, headlight restoration and realistically any surface you can use a buffing ball on whether it is your custom 2 or 3 piece wheels, painted, polished/alloy, to even your boat, your bullbar on your other ride/weekender and so on! The buffing balls are made of a high quality patented viscose material so they will not deteriorate like many other foam buffing balls on the market which are machine washable for long term use!
Flitz Mag/Alloy Wheel Restoration Kit Car Care Products / Flitz / Exterior / Wheel Cleaners / Mag Wheel Restoration & Care Kit
Flitz Headlight Restoration Kit
Super Mini 2" Buff Ball for those tighter areas and handy for motorbikes as well as wheels!
Flitz Speed Wax very similar to what Duragloss Aquawax is however it smells like Bananas i have to say. It is one of our new 'favourite' scented products. Great glow/finish this leaves as i couldn't help myself and tried it out over the weekend!
Check out the Full Range of the Flitz Products here!
Car Care Products Australia
www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
Sydney - Brisbane - Melbourne
Stoner Tarminator
Originally Posted by www.CarCareProducts.com
At only $18.95
Car Care Products now have our "Wash", "Rinse" & "Wheels" Bucket Stickers available for your Two & Three Bucket Wash Metheods!
Available in 2 Sets.
Set 1 with "Wash & Rinse" Stickers @ $4.95 ;
Set 2 with "Wash, Rinse & Wheels" Stickers @ $5.95;
Click Here
A few products to mention for the June Month that are now available.
Dodo Juice 3 Bucket Sticker Set - "Wash", "Rinse" & "Wheels"
Dodo Juice have released a 3 Sticker Bucket Set so you do not confuse which Bucket is Rinse, which is Wash and is that the Wheels Bucket?
Transform your ordinary forgotten buckets with the Dodo Juice ‘Wash, ‘Rinse’ & ‘Wheels’ Stickers.
This Pack includes 3 Stickers and is made from a seven year laminated vinyl.
Vikan's Deluxe Multipurpose Soft Brush
This Vikan Delux Multi Purpose Brush is ergonomically designed to be comfortable, effective and easy to use on all surfaces such as Interior Carpets, Upholstery, Plastic Trimmings and Wheels.
The soft rubber edging prevents any damage to the surface ,with bristles that are made from soft polyester which gently clean without damaging or scratching sensitive surfaces.
Mint Round Tyre Foam Applicator
The Round Tyre Foam Applicator allows the flexible foam to work through the tyres intricate ribbing, letters and patterns giving a more consistent finish. You will achieve an even result without any excess sling found on your cars paintwork.
Mint Ultra Soft Foam Wax Applicator
The Mint Ultra Soft Black Wax Foam Wax Applicator ensures the softest and highest quality foam for applying your favourite wax or sealant to your car’s paintwork. Made from an ultra-soft double sided high quality foam, it’s a perfect size to hold and wax evenly and smoothly without scratching or marring the paints surface.
Nanolex Glass Sealant Ultra Basic Kit
Nanolex Glass Sealant Ultra is a new high technology sealant / coating especially for glass that repels water and dirt improving visibility all-round with maximum durability.
The Nanotechnology is designed to coat the glass surface with a durable layer that will help repel rain and dirt, making it much harder for these contaminants to adhere to the glass and simply ‘slip off’ with the motion of the car.
As you drive, the car’s glass will get dirty and this then makes it hard for rain to slip off the surface. This dirt and other pollutants, like bugs, are then wiped over the windscreen to further blur vision or after some time the combination of this rain and dirt mixture actual ‘marks’ the glass through acidity and minerals, this marking is usually hard or impossible to remove by washing or even glass cleaner sprays.
By the application of this advanced chemical sealant rain will ‘slip’ off the glass taking any dirt particles with it, leaving clean glass and perfect visibility. The complex molecular technology makes the coating completely invisible and water will move off glass once the car reaches about 50km/h making it ideal for highway or country driving.
Nanolex Glass Sealant is superior to all other glass products because of its durable composition, and depending on driving and weather conditions, it can last for 12+ months on windscreens and longer on glass surfaces without wipers.
[videp]http://www.youtube.com/watch?v=aulVUoMv7oI[/video]
Duragloss Rinseless Wash is now available in store for $22.95
The new Duragloss Rinseless Wash (RW) is a very versatile product that offers solutions to washing your car without having to use lots of water, as a spray detailer and even a waterless wash. You can effectively wash your car using only 10 litres of water, which makes this a great product for all those that are limited to washing the car in basements, garages or who do not have access to a hose.
The high technology formula of Rinseless Wash captures the dirt with a lubricating Polymer, which reduces the chance of marring or scratching during the washing process. And with added Aquawax this product also adds protection or increases the durability of your existing sealant or wax, as it washes!
You can also use Rinseless Wash as a Quick Detailing Spray, simply add 75ml to 425ml of water and shake well. This can be sprayed onto a section and wiped clean with a soft microfibre to add gloss and protection, whilst removing dust and fingerprints.
Dodo Juice Bucket Sticker Set
We have now changed over to a new style Waffle Weave Drying Towel which is unlike any other currently around! Much softer, and much more absorbent than any other we have used.
We also now have the Large Waffle Weave Drying towel and Extra Large Waffle Weave Drying Towels and of course all are in stock.
Microfibre Waffle Weave Regular (large) Drying Towel (60x40) ( $15.95
And the Microfibre Waffle Weave Extra Large Drying Towel (90x60) $27.95
Mint also now has a 'Deluxe' Wash Mitt and the new Microfibre Uber Plush Cloth made from a high quality and incredibly soft Korean Microfibre like all the other Microfibre Products we stock. The Uber Cloth i have to say is one of the softest cloth we have seen so far to date!
Mint Microfibre Deluxe Wash Mitt $16.95
Mint Microfibre Uber Plush Cloth $16.95
Thinking about spending around $300 on the Enthusiasts Total Wash Essentials Kit and some nanolex sealant. Any chance of a discount or free delivery?
Car care products are very reasonably priced for the products they are selling, considering most of their products are not available at you average auto store.
You wont get the likes of Free shipping.....BUT.......as a VW watercooled member we have a code that is entered in the checkout stage on their web site when purchasing to receive a 10% discount.
White Scirocco R
White MK3 Golf 2dr
White Caddy (Work Van)
08 Golf GTI - SOLD
