12- Cut out all holes and reinstall linner.
13- Have a sit in theese...
Enjoy what you have accomplished!
If I can give a hint, it would be wise to cut an X ( corner to corner ) where the Dome Light Switch goes prior to rolling it once glued. It will allow you to roll the fabric correctly into that curb ( right where the miror is, between the switch and windshield ) and reduce the chance of having creasses.
Make it a bit smaller that the actual cut-out, cause you will want to make a nice border after. Besides, you don't know exactly how the fabric stretches and you could end-up having a cut in the fabric where you don't want to.
In a SHORTER VERSION:
Thanks to Kevin
Thanks Sean, yep... and I did try to pull the rest off, so there are wholes on the foam. However, mine only appeared to have a layer of fabric and then the foam?! and now it looks crap, I reckon I better leave it for the pro's to do then. If I need the foam to be redo, will it cost more?
Cheers,
Carlson
Nice description and Job Sean.
Is your car a 2 door? Sweet. And now a 16v GTI Mk3![]()
Err....
I didn't do that work, i stole that info from another forum...
IT's NOT ME!!
You robber!
Nice description tho. fair enuff.
