Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Mk3 roof trimming...
    Feb 2006
    Camberwell, Victoria
    12- Cut out all holes and reinstall linner.
    13- Have a sit in theese...
    Enjoy what you have accomplished!
    Feb 2006
    Feb 2006
    If I can give a hint, it would be wise to cut an X ( corner to corner ) where the Dome Light Switch goes prior to rolling it once glued. It will allow you to roll the fabric correctly into that curb ( right where the miror is, between the switch and windshield ) and reduce the chance of having creasses.
    Make it a bit smaller that the actual cut-out, cause you will want to make a nice border after. Besides, you don't know exactly how the fabric stretches and you could end-up having a cut in the fabric where you don't want to.
    In a SHORTER VERSION:
    Thanks to Kevin
    Apr 2006
    Carlton, VIC (HK now)
    Thanks Sean, yep... and I did try to pull the rest off, so there are wholes on the foam. However, mine only appeared to have a layer of fabric and then the foam?! and now it looks crap, I reckon I better leave it for the pro's to do then. If I need the foam to be redo, will it cost more?
    Cheers,
    Carlson
    Camden, Sydney
    Nice description and Job Sean.
    Is your car a 2 door? Sweet. And now a 16v GTI Mk3
    Feb 2006
    Err....
    I didn't do that work, i stole that info from another forum...
    IT's NOT ME!!
    Camden, Sydney
    You robber!
    Nice description tho. fair enuff.
Similar Threads
  1. Hole in the roof
    By auspassat in forum Passat (B4 & B5)
    Last Post: 02-05-2007, 05:06 PM
  2. Roof Lining
    By Darks RS in forum Bodywork/Trim & Detailing
    Last Post: 11-10-2006, 02:13 PM
  3. Replies: 17
    Last Post: 07-01-2006, 04:35 PM
