Originally Posted by
Augy
What I did was, basically take all the little bits of plastic that was coated in rubber, sand it using 80, then 120 grit paper.
Then wet sanded from 320, 800, 1200, then 2000. Then, I used a plastic polish, like Mcguires (sp?) to really polish everything. Then, you can take some minieral oil, and polish it futher. Makes it really shine.
So, if you don't mind the polished looked, then go for it. Then that's what I would suggest. Doesn't cost much, but requires times.
I'm still working on mine. About to take the glove box out to get at the center console.
