Results 1 to 6 of 6
Thread: How to fix your mk2 parcel shelf!!
    Dec 2008
    Bentleigh, Melbourne
    this is a guide of how to fix your mk2 golf parcel shelf...... well how i did it
    my parcel shelf has the infamous speaker holes that have also made it cave in the middle. so i thought it needed some stiffening up to last for ever!!! (yes i may have gone a bit over the top)
    first of all... to rip off the old fabric
    where the speakers holes are, we want to cover it up so... i cut out a rectangular shape, so i can splice a piece in.
    grab some chipboard/plywood whatever material the same thickness as the shelf.
    then cut the piece about 12mm larger than the hole you've just cut in the shelf (leaving 6mm on each side)..
    to splice, chamfer all edges on both the outside of the insert and the cutout to make the piece sit neatly in the cutout.
    after both are fitting nicely, place some epoxy on all chamfers on both mating sides.
    the stick down and place some weight onto the parts.
    after epoxy has set, cut some fibreglass out to glass the underneath side of the parcel shelf
    and also, because my parcel shelf has a massive bow in it i made up some strips of timber to stiffen it up.
    next step, glassing.
    Dec 2008
    apply some more glass onto side and front edges to stiffen up even more!!
    after finished glassing let resin set, then grind and sand back till smooth.
    then to keep it OEM, drill some more holes
    next step is to apply the fabric.....
    i found out the OEM fabric is black front runner and some felty sort-of carpet stuff,
    which i bought from Australian Trim Supply in Dandenong.
    what you also need is some Kwik Grip Gel (from bunnings). not normal Kwik Grip as it will seap through the fabric
    firstly cut your fabric roughly to size (leave a fair bit extra) and smear a thin layer of the gel all over the fabric and on the parcel shelf,
    wait until the glue has gone off (not sticky) and then start applying fabric, starting from front and working to the rear.
    do the same with the underneath side.
    join both the carpets together, let it dry a bit to stick better. then trim all edges until looks how you want it.
    And Voila, a new parcel shelf!!!!
    i probably missed a few things so just ask
    Top job !!! I hope next owner of it won't cut another 6x9 hole
    question, if you want OEM look why did you carpet the bottom as well ???
    Jun 2007
    Eastern Suburbs Melbourne
    looks good!
    i like volkswagens
    Dec 2008
    Quote Originally Posted by RedMk2Gti View Post
    mine originally had black carpet underneath, with vw logos.
    Maybe it's just a pre 90's thing. But it looks soooooo much better than painted
    Aug 2009
    Darwin, NT
    Very nice job!
    - Mk2 Golf GTI 16v, 2-door, Tornado Rot, BBS RS, 1988 - SOLD
    - E30 325i Coupe, Manual, Alpinweiss
    - E30 325i Touring, Manual, Diamantschwarz x 2
    - On the lookout for another E30 325i Coupe, Manual (red would be nice)...
