Filling in a few gaps
Drivers skin (fabric) removed from the bolster. Showing hole and fading, thus reason for changing.
The pieces I changed for this particualr GTI seat. Old bit are on the top row.
Basically rear was split on the donor seat, so original vinyl needed to be used for the back section. Donor bolster fabric from a 5 door seat and the original fabric for the main insert of the seat flipped over and restitched.
The finished skin stitched back together.
And the old nonsense.
With regards to flipping the skins. Here is a cabrio piece of fabric that I`m sure most of you would chuck out.
However, if you remove the material and flip it over, rip off the backing and peel away the foam. this one has got wet and so the foam has disintegrated, scrape that away and the same pattern, but unfaded and not dameged is revealed
