Bought some vinyl wrap for my B-pillars because I've never liked the slash of red between the tint windows (although I'm not totally convinced my solution will be any better - maybe I should have got piano black rather than satin))
Just attempted to apply some & have come to the conclusion I have as much skill at this as brain surgery & understanding women.
If somebody has a clue & can help me out ...
WARNING: don't click onto larger pics if you have a love of fine craftsmanship
Hard to say from the photo but it does not look bad - no bubbles or wrinkles
I assume the bit you are not happy with is the bottom right corner of the windscreen?
I would cut a short thin strip and lay that down on the inner edge first
Then apply the main piece (with a little overlap if needed)
It's a neat idea - I want to see the end result, side on, when your finished please
